Old 12-06-2007, 07:53 PM
pbrizzle86 pbrizzle86 is offline
Send a message via AIM to pbrizzle86
y8 throttle body
hey i just did the mini me swap with a y8 head on a zc block and im picking up the y8 manifold was wondering if i could use the 90 si tb on this manifold or should i get the y8 tb. also if i do get the y8 tb will all the wiring match up to the throttle position and i belive the map sensor is on the y8 tb or will i have to change anything thanks paul
Old 12-06-2007, 11:29 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: y8 throttle body
Almost any honda tb will work with it.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 12-07-2007, 09:43 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
The tps is located different between the y8 and si. But I'm sure you can make it work
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 12-07-2007, 10:28 AM
FrodoGT's Avatar
If you use the y8 tb you would have to cut the plug and put the obd2 one on. If you already have the a6 tb id just use that and call it a day.
Current project:
Rio Red 91 hatch.
Old 12-07-2007, 12:19 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
no! you shouldn't have to cut the plug... just depin the wires and plug them back in the right places on the new plug.. most the plugs on my car are from OBD-1 civic's from when we did the MPFI swap... they just plug right in, and they don't have problems there.
It just looks nicer... lol. that's my
Old 12-07-2007, 03:22 PM
FrodoGT's Avatar
But the y8 is obd-2. You could try to depin th plug if its the same pins then great.
Current project:
Rio Red 91 hatch.
Old 12-07-2007, 11:21 PM
they should be, I don't see a reason why they wouldn't be, but I haven't personally done it w/ OBD2 plugs... the wires all most likely have the same ends on them tho, so try that first.. unless you don't care that your wiring is all taped up and stuff, in which case, do as you will.
Old 12-07-2007, 11:37 PM
FrodoGT's Avatar
Solder and heatshrink man.. have some pride :P
Current project:
Rio Red 91 hatch.
Old 12-08-2007, 01:00 AM
if I can't swap pinouts, solder and heatshrink is the next obvious way for me... I seldom use butt connectors, and I never just join wires and tape them up unless its' a quick cut-together just to get home, then I fix it the right way.
Old 12-08-2007, 10:30 AM
FrodoGT's Avatar
Id rather twist a wire together the right way than use a butt connector..at least when it comes to under the hood. My crx had the whole engine harness attached with those little bastards and had to take each one of them out and solder..
Current project:
Rio Red 91 hatch.
Old 12-08-2007, 02:30 PM
Nah, when I use butt connectors, I use aerospace industry grade connectors.... you have to twist them on to the wire, then heat them up, which happens from engine bay heat anyway... so then you don't have to tape it up, b/c it's waterproof.. (and high-altitude proof) I have a small 5 lb. bag of them for everything from 30g on up to 2g wire.
Old 12-08-2007, 11:24 PM
kris's Avatar
kris kris is offline
Off playing with fire.
A tps is a tps is a tps. It doesnt matter what year it came from. The only tps that is different is the pre OBD D15 from the dpfi manifold.
