Old 12-06-2007, 05:53 PM
ugotme ugotme is offline
Death Wobble
Hello, I have a 92 c/k 3500, 2WD, manual trans, 454, 1ton dually.
I have the death wobble starting so I need to get busy on the front end rebuild what all do I need to do, I am the original owner and the truck runs perfect (kept up on engine/tranny/rear end maint.) ball joints, shocks, what else to do it right and where to buy the correct parts the first time?
Old 12-07-2007, 03:33 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Death Wobble
If you havn't already, check to see what exactly is loose. Then replace those parts. I always use Moog chassis parts, never had a problem.
It is possible that REALLY out of balance tires could cause a bad wobble too. I've had mud on my wheels after offroading and at 30 mph it feels like the wheel is bouncing off the ground
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 12-07-2007, 05:58 PM
bigcoconut bigcoconut is offline
Re: Death Wobble
Moog is definitly the better aftermarket parts available. I've always used them in the past. I have however used the polyurethane (black) bushings & end links on the anti-roll bars and they have performed very well there.
My buddy used polyurethane (Performance Suspension) everywhere on his S-10, and it rides great. The only problem is it squeaks like crazy, like an old 60's car would when a fat guy/girl gets out of it. He may not have installed them correctly but my money is definitly with stock replacement Moog parts.
"Yes I have a truck and No I won't help you move your stuff..."
2008 Kawasaki KLR650 2500mi (fairweather commuter)
1992 C1500 Silverado 235,000mi (daily, not so much anymore, driver)
1999 Venture 120,000mi (moms vacation bus)
1989 Dodge Ramcharger SOLD, Yee-Freak'in-Haw
Old 03-13-2009, 11:14 AM
cccantrell cccantrell is offline
Re: Death Wobble
hi i have 1992 3500hd and it does'ent have ball joints it has king pins!and front leaf springs.
Old 03-31-2009, 09:50 PM
taterhead taterhead is offline
Re: Death Wobble
Make sure you dont have any water in you tires ,, had a new truck several years back and had a tire that was leaking ,, getting air in strange places and ended up withn about a gallon of water in my tire,,, woble sometimes and at differrent speeds,,,, like ridin in a pea thrasher but did not do it all the time,, ,,,,,,,,a few cans of fix aflat will do the same thing
