Old 12-06-2007, 03:09 PM
gln7 gln7 is offline
Hard-shift at 4th gear
When my ‘95 Lumina van (with 3.8 engine and 4-speed automatic) shifts into 4th gear, I feel a jolt or clunk when accelerating on the level or uphill. When it shifts going downhill I don’t feel this jolt. Then when going uphill and slowing down, I feel a little jolt when it goes back into 3rd. Also, now and then, when in 4th gear, about 45 or 50 mph or so, I’ll feel sort of a "rumble" or vibration for a few seconds (maybe in the front halfshafts?) I don’t have any problem in the other gears. If a CV joint is going bad, would there be these jolts and vibrations in only one gear? Any ideas? Thanks.
Old 12-06-2007, 03:16 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Hard-shift at 4th gear
I'd almost suspect a TCC with harsh and delayed release...they will sometimes chatter in and out of lock rapidly at the speed you describe when starting to go bad...
I don't think it would be in the axles...
You should probably check the motor mounts and roll restrictors too..
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
