Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-06-2007, 02:44 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Angry Battery Dies When Cold Out
I mentioned this in another thread, but I know most people weren't looking there. It's been cold twice this year, and my batter has died both times. Once in the garage (sat for a week without moving) and now once not moving for a couple days in front of my house under snow. It can sit for months in the summer and start right up, but here it dies in winter. Did all the other years too. No blowing fuses, new battery (last year; Die Hard with max cranking power) and no shorts as far as I can tell. Because I'd have them problems all year round.
I can't find any info on batteries dying when cold. Just when really hot. The little plastic try is below the battery as someone suggested that it needs to be on plastic. But thats only true with older batteries. It is touching the strut tower and I'm going to put something between the 2. Any ideas though? Thanks/
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 12-06-2007, 03:25 PM
2of9 2of9 is offline
Re: Battery Dies When Cold Out
if it sits in the cold for a long time, like 7 days or more without being turned on in the cold, its also possible the fluid in the battery may have frozen.
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 12-06-2007, 03:35 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
I have only heard that batteries may freeze when they are dead.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 12-06-2007, 11:40 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
I'm not sure why, but my car kinda does the same thing. If I don't run it for atleast a few minutes every 2-3 days during the winter, its a bitch to start. And my battery is only about a year old also, although its a shitty EverStart or something like that instead of a DieHard.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 12-07-2007, 07:08 AM
david-b's Avatar
Dave is THAT guy
Does it completely die after a couple days though? Even like 2 days when it's really cold?
75 Monte Carlo
Old 12-07-2007, 10:43 AM
violent31601's Avatar
violent31601 violent31601 is offline
Send a message via AIM to violent31601
does your Eclipse have an alarm system (or even the factory alarm) that will drain it pretty good
Old 12-07-2007, 01:59 PM
david-b's Avatar
Dave is THAT guy
No. I did the first winter and it kept dying so I took it out.
I asked this dude at work whos sister had a Talon (also 95 NT) back in the days. He said she had the same problem with it. That was perfect in summer, but battery would die in the cold after a couple days every winter. They kept replacing the batteries but it didn't fix it. She had no shorts or anything. He then went on to say, no offense, but those cars sucked and were poorly made... blah blah blah. He almost got punch in the face. Anyways... so ya.
75 Monte Carlo
Old 12-07-2007, 02:22 PM
Holset powered 420a
My car has no problems with the battery draining. You HAVE to have a drain somewhere. Thats the only thing that could cause the battery to die.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-07-2007, 02:56 PM
david-b's Avatar
Dave is THAT guy
But it's not making any sense to me though. Everything is exactly the same between summer and winter on my car but the battery dies in days when cold. If there was a drain/short, it would constantly be dying. Cold doesn't speed up things like that.
75 Monte Carlo
Old 12-07-2007, 03:12 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
That's not necessarily true. If it's a short on a very tiny wire, the wire will get very hot and have lots of resistance being as resistance increases with heat. Therefore the colder it is, the less resistance it has and it would drain faster. But that's getting to be a pretty long shot.
95 Talon TSI AWD
97 Eclipse GST
Old 12-08-2007, 12:25 AM
I've never let it get to that point for fear of it doing just that. I run it for a few minutes everyday during the winter, regardless if it leaves the driveway. To be honest though, I don't think that after 2 days it would completely die. Its just a LOT harder to start.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 12-08-2007, 12:26 PM
Holset powered 420a
I dont know why you guys have problems like this. I have never had anything like this happen to my car. But then again I drive it almost every day and it doesn't really get below 20F here. That might be the difference
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-08-2007, 03:49 PM
david-b's Avatar
Dave is THAT guy
My car sits usually from Monday-Thursday and moves Friday night then. I'm going to be starting it everyday during the week now just to get it going an letting it sit. I've got a little coolant issue now too so it'll give me some heat while working on that then. Damn cold, snowy, wintery Chicago weather crap.
75 Monte Carlo
Old 12-08-2007, 07:04 PM
Holset powered 420a
Damn Dave it must suck to be up there. Monday is suppose to hit 81 here is SC. he he
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-08-2007, 08:12 PM
The HIGH in ND tomorrow is supposed to be -1 F. Right now I think it's -10 and it supposed to drop at least another 10 degrees.
95 Talon TSI AWD
97 Eclipse GST
