Old 12-06-2007, 02:03 PM
joeshorts joeshorts is offline
'00 vortec 6 auto
Just purchased this used from a dealer, 90k miles and have run 2 tanks of gas thru it and am averaging 12.5 mpg. Unacceptable. I will change plugs, wires, rotor, and cap, and put in a k&N filter tomorrow, but what else can I do to get her running a little more gas friendly?
Old 12-06-2007, 07:10 PM
old_master's Avatar
Advisor/Moderator
Re: '00 vortec 6 auto
At 90K miles, several things are due: AC Delco Platinum or double platinum plugs ONLY. AC Delco or Autolite Professional series wires. Preferrably AC Delco cap and rotor. All oxygen sensors, (Bosch). Any name brand air filter, not Fram or K&N. Any name brand fuel filter. Check the brakes and make sure they aren't dragging. Check front wheel alignment. These items should get your mileage up as high as possible. Keep in mind, driving habits and weather conditions affect fuel mileage also.
Old 12-10-2007, 12:02 AM
Old 12-10-2007, 12:07 AM
The Distributor cap was corroded, but as I was taking it off, the front torx screw was just spinning and spinning. Upon closer inspection the piece that the torx screws into to hold it down is broken off. My chevy dealer says I need to replace the whole distributor, thier price is over 320 new, napa says 180 ish. I threw on a c clamp to get me by until I can get the part ordered or go to the local junkyards to find a replacement.
Old 12-10-2007, 06:13 PM
old_master's Avatar
Advisor/Moderator
The clamp should work temporarily. I question the corrosion though. When the cap is replaced, a small amount of silicone dielectric grease is applied to each terminal in the cap, as the current passes through the grease it crystalizes and could be mistaken for corrosion.
