Old 12-06-2007, 11:05 AM
Quinnyfreefly Quinnyfreefly is offline
89 Cherokee Erratic Idle
Hi,
89 Cherokee automatic. Starts like a dream as usual, but begins to drop rpms periodicaly. Sometimes its fine and others I will put it in drive and unless I am quick and give it a lot of gas it stalls. Ive done searches but cannot find any simalair cases.
Any input?
Quinny
Old 12-06-2007, 11:41 AM
citizen@large's Avatar
citizen@large citizen@large is offline
Re: 89 Cherokee Eratic Idle
TPS- Throttle Position Sensor
This thing being out of adjustment on my '89, gave me issues for months until I got it adjustd right.
Old 12-06-2007, 11:46 AM
TPS, I will go look it up and see what I can do. Let you know how it went in a bit.
Thanks
Quinny
Old 12-06-2007, 12:08 PM
I back probed the TPS as instucted by manual. All readings where fine. I have cleaned the throttle body. This is why Im a bit stuck, Checked O2 sensor, its fine.
Any other ideas?
Quinny
Old 12-06-2007, 12:22 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 89 Cherokee Erratic Idle
How long since you replaced the plugs/cap/rotor?
Air filter ok?
Fuel pressure good?
Did the problem start recently? On my 2000, when I have the defrost on I'll get a surge in rpm's as it turns on and off. Not enough to kill the engine though.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 12-06-2007, 12:25 PM
Hi,
Long time no speak, air filter is clean, fuel pressure is good, cap and rotor are fine, gonna go pull the plugs and have a quick check.
Back in 20 mins!
Quinny
Old 12-06-2007, 12:29 PM
I may actually still be on line in 19 minutes.
How about the plug wires? They can be bad even if they look ok...if showing signs of wear that could contribute.
Old 12-06-2007, 12:41 PM
I got to the workshop and my Step Dad already had them out and they look good. I rechecked the distributer roter etc and the rotor looks pretty bad! I only replaced it 1 yr ago. I will get a new one this afternoon. The wires were replaced at the same time and they look good too. Any ideas as to why the rotor will degrade so quickly?
If there is a reason why I would love to fix it.
Quinny
Old 12-06-2007, 12:47 PM
Couple of thoughts on the rotor:
1st, it's the miles, not the time. The rotor only degrades when used. I've always replaced mine each 20000-30000 miles, and never had a problem. Make sure to replace the rotor at the same time.
2nd, what cap & rotor did you use? Copper (penny colored contacts) is the best and longest lasting, and worth any extra you might pay. You can also get aluminum (silver contacts inside the cap) which is usually cheaper but doesn't last as long. Also I've found some vehicles run much worse with the aluminum.
What I've found in older vehicles with higher mileage is that each little electrical issue adds up and can make bad things happen. I've seen a vehicle that would hardly run start to run perfectly with new plugs, cap, rotor and wires.
Old 12-06-2007, 12:54 PM
Aluminum is what I used. Will buy a copper and see what happens. Will also buy a rotor cap. Well only time will tell now but I will let you know tonight what worked and what didnt
Quinny
Old 12-06-2007, 12:57 PM
I think you'll be pleasantly surprised - let us know.
Old 12-06-2007, 02:51 PM
Shoot. I'm interested to find out what happens next. *bites nails*
Old 12-06-2007, 06:51 PM
Hope citizen@large has some nails left! Still happening.
Maybe I can describe it a bit better. I will be driving and come to a light and stop. 1 out of every 5 times it tries to stall when I give it gas to leave intersection or sometimes idles eraticly when stopped and I need to put it in neutral and give it gas quick before it stalls.
Quinny:o
Old 12-06-2007, 06:52 PM
Oh and how would you adjust the TPS? Might try fiddling with it and see what happens.
Old 12-07-2007, 02:06 PM
Well now, that could get you into more issues than you'd expect...
Just make sure to clearly mark the origional position of the TPS before you go and adjust it.
Anyway, it's located on the throttle body and has two torx-style screws that keep it in position. Just loosen them and barely adjust it one way or the other. Drive it, repeat.
Like I said, it took me a long while by this method to find the 'sweet spot'.
Also look at you IAC- (idle air control / idle stepper motor) It may need cleaning or replacing. Forgot about that one...
From- http://www.lunghd.com/Tech_Articles/...iagnostics.htm
Throttle Position Sensor (TPS)
TPS and Idle Stepper Motor.
Located on throttle body facing toward radiator. Located on the right side of the front of the throttle body. To test, disconnect the connector at the TPS. Check the voltage at TPS connector pins B (Ground) and A (5.0 volt supply) with the ignition on. If you see about 5 volts, hook up the connector again. and check the voltage at TPS terminals C (positive) and B (Ground) with the ignition on and the throttle plate closed. You should notice approximately 0.8 volts. If you see that voltage, your TPS and wiring should be ok. If not, you'll have to adjust the TPS to get that voltage. If you cannot adjust the TPS to get that voltage, you'll have to replace the TPS and adjust the new one properly. Also, with the voltmeter hooked (terminal C) up and the ignition on, move the TPS arm down and back up slowly and watch the voltage. The change should be increasing and smooth. If there are any dead spots or it is not smooth, it probably needs to be replaced.
> What does it do? The voltage is interpreted by the ECU to determine current engine operating conditions. Just as a note to you, the automatic transmission versions have 2 integral connectors (1 for ECU and 1 for tranny). If you have the auto, make sure you're checking the right connector (I'm not exactly sure what it looks like as I have the manual tranny).
Update: Suggestion: If you are having intermittant idle / surge issues and can't quite get the voltages to set right - before going out to buy a new TPS try checking your ground connection. Renix engines are notorious for having bad / faulty ground connections as a result of age and not so great design in the connectors. A common "fix" is to add a jumper ground wire from the TPS ground that bypasses the connector and harness entirely.
  1. First - Check ALL of your engine ground connections.
  2. Second - Check the ground wire from your TPS to the firewall to ensure that there is not a poor circuit to ground. If the circuit resistance is high then the voltage reading will be incorrect to the ECU and the computer will not know what the throttle opening is actually at & the engine will not run or shift properly.
