Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-06-2007, 04:23 AM
midnightsliding midnightsliding is offline
Send a message via AIM to midnightsliding
No spark.
so i just replaced my 1999 GMC 5.7 K1500 suburban engine this past week and im 99% sure everything it pluged in ( im missing the knock sensor) but other then that everything is good. is their anything you guys would suggest to check for spark? i have 12v at the coil and the distributor with the key turned onto the ON position, and good grounds. just wanted to know if their was something that i might to know about lil key less entry stopping it or something stupid thanks for your help.
Old 12-08-2007, 06:44 AM
lox4rox lox4rox is offline
Re: No spark.
Is the security light coming on and staying on more then 10 seconds after you turn the key to the on position? If so, do a search for the reset procedure of your Passlock system.
Old 12-08-2007, 09:22 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: No spark.
Spark is trigered by crankshaft sensor on front of engine.
Is it pluged in and working good?
ALSO GO OVER AND CHECK ALL FUSES AND POWER FEEDS AND GROUNDS.
MT
Old 12-08-2007, 12:26 PM
Re: No spark.
yes well i know its pluged in now if it is good i dunno ill re-check that today. and yes i have already check them all under the hood any where else i should check fuse/relay wise?
