Go Back   Automotive Forums Car Chat > Chevrolet > El Camino
Old 12-05-2007, 09:22 PM
nick romano nick romano is offline
Transmission trouble
Hi Gang,
My 1980 El Camino started acting up for the first time since I bought it. Yesterday I reversed out of the driveway, put it into drive, and nothing happened. All shift positions responded like neutral. I shut it down, waited a minute, then cranked it up and it ran all day. Today the same thing happened, but reverse to drive was no problem. I made it to a stop light, then when the light changed I hit the gas and had the same problem. Once again all shift positions responded like neutral. I shut it down, fired it up a minute later, and it worked all day.
The car is an automatic with a 350 Edlebrock, lock up and mild stall, and until yesterday has run beautifully. Any advice will be very much appreciated.
Thank you,
Nick
Old 12-09-2007, 09:09 AM
454COR 454COR is offline
Re: Transmission trouble
Sounds like your low on ATF.
Old 12-21-2007, 04:24 PM
j cAT j cAT is offline
Originally Posted by nick romano
Hi Gang,
Thank you,
Nick
i think vacuum modulator. its been a while that i had 350 tranny. check vac to trans.........
