Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 12-05-2007, 09:03 PM
RJosephR RJosephR is offline
no heat
Hello, my daughter has a 94 olds 88, 3800 motor,it has dual heat control, driver and passanger. i have changed the thermostat and the coolant level is good. both of the controls are set to hot, but we get nothing but cold air. any suggestions ? thanks in advance.
Old 12-06-2007, 05:55 AM
maxwedge maxwedge is offline
A990 racer
Re: no heat
Welcome to AF, check for hot coolant flow in the heater hoses first.
Old 12-09-2007, 06:27 PM
Re: no heat
Thanks for your reply maxwedge, I have hot coolant flow in heater hoses. today i noticed driver side was getting warm air out vents, however the passenger side was all cold air. sounds like it might be some sort of control valve. just a reminder it does have dual climate control. again thanks for any help you may offer.
Old 12-09-2007, 06:32 PM
A990 racer
Re: no heat
Is the automatic HVAC or manual? Also look at the actuators make sure they are in the full heat position. Even though you have what seems like coolant flow, in the end if all else checks good the heater core could be restricted.
Old 12-09-2007, 06:42 PM
Re: no heat
Im not sure what your question is about the hvac, is it automatic or manual. both the driver side and the passenger side heat there is a manual heat/cool control knob.
