Old 12-05-2007, 06:38 PM
nlohman0717 nlohman0717 is offline
Blazer 4wd problems
I'm having some major problems with my 4wd on my 95 blazer. I have read a lot of the posts on this particular topic, but my car is doing some things i havent seen yet. First, when I switch from 2hi to 4hi the light goes on, but I do not hear the 4wd engage. If I switch to 4lo the 4wd does engage and works fine..i think. When I switch back to 2hi the light does not go on. occasionally, I will press one of the 3 buttons on the dash and both the 4hi and 4lo blinks. I have recently replaced the actuator under the battery, so i know it is not that. Its beginning to become that time of year when i need 4wd so please help!!!!
Old 12-05-2007, 07:01 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Blazer 4wd problems
Welcome to AF.
Does it help to put transmission in netural ar back up and roll forward a little?
Are your tires a good matched set?
Has it got good vacuum and good clean vacuum lines with any fluid in them?
Is the transfer case fluid and transmission fluid level good?
MT
Old 12-05-2007, 10:45 PM
I did try to put the car in neutral and I moved it forward a bit, but not reverse. I just recently put brand new all 4 matching tires on the car so I dont think that is a problem. I checked the vacum and that seems good. but I have not checked the fluid level in the transfer case or the tranny fluid.
