Old 12-05-2007, 03:12 PM
xcassix0 xcassix0 is offline
overheating problem
i have a pontiac grand prix (1994) and have been having problems with overheating. i have about 3 minutes before the temp shoots up to 260. i tried removing the thermostat to see if it would create an immediate result however it made no difference. my coolant tank is full and there is no sign of leakage from anywhere. could this mean its the water pump? how easy would it be to replace myself? i cant afford to spend very much, so if its feasible i would like to be able to replace it on my own however i want to know if it could be another problem before i start taking everything apart.
Old 12-05-2007, 04:24 PM
Burtnette Burtnette is offline
Re: overheating problem
When it shoots up high do you see any steam anywhere?
CURRENT:
1997 Grand Prix GTP
Mods:
U-bend/Res Delete
3.4"
MSD 8.5mm
TR6s
ZZP 1.0 PCM
72mm TB w/ TB spacer
WizAired CAI
3" DP w/ Borla Pro XS mufflers
OLD:
1995 Dodge Stealth
Old 12-06-2007, 10:40 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
What motor is it? why dont you put a new AC delco thermostat in it, and then make sure you bleed all the air from the cooling system.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 12-07-2007, 08:33 AM
well the problem no longer seems to be the thermostat. and no, no steam anywhere...
Old 12-07-2007, 08:54 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Let's ask again, what engine does your car have?
While we're at it, how many miles, and is the CEL on?
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 12-07-2007, 12:16 PM
tblake's Avatar
In God We Trust
good point Rich.... Are you basing your overheading problem just on the guage or does the motor get very warm? Next time it is started why dont you feel the upper and lower radiator hoses just before it overheats. Note the pressure and also relative temperature. Dont burn yourself. Something tells me your going to have a very high pressure right after startup.
Old 12-07-2007, 01:52 PM
wlkjr's Avatar
wlkjr wlkjr is offline
Sounds to me like you have either another bad thermostat, air not purged from the system when you changed out the old one, not enough coolant in the system, water pump impeller spinning on shaft, collapsed hose, or heaven forbid, a bad head gasket.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
