Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 12-05-2007, 02:55 PM
kevin23 kevin23 is offline
89 Ranger runs rough or misfires
89 4 cyl. EFI with 8 plugs, 180k starts and runs well at idle but runs rough or misfires under acceleration or going up hills. I suspect plug wires but can't find one leaking, not even at night.
Also where is the PCV valve on these models, I can't find it..........
Thanks
Footnote: I pulled 3 plugs at random and they all had a nice frosty white apperance, correct gap and no gunk on them. Now I am second guessing the plugwire need ???
Old 12-06-2007, 02:07 PM
TeamExploder TeamExploder is offline
Send a message via AIM to TeamExploder
Re: 89 Ranger runs rough or misfires
If someone was under your hood before this happend I'd make sure your firing order is right and then I would go for new plug wires poss. new plugs because sometimes even good looking ones could be bad.
1996 Explorer XLT 4X4 Auto. 4.0 OHV BWM to Fulltime and auto 4X4
1999 Malibu. 2.4L DOHC Auto
2000 Explorer XLT 4X4 Auto 4.0 SOHC
Old 12-09-2007, 11:13 PM
Solution: New plugs and wires has this old Ranger purring like a kitten. The plugs were still OK but since the wires are such a bugger to put on, (the drivers side) I put everything in new. I had two of the eight wires that were obviously bad.
Still haven't found the elusive PCV valve...........
Old 01-30-2008, 07:07 AM
backerm1's Avatar
backerm1 backerm1 is offline
PCV should be underneath the alternator.
