Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 12-05-2007, 02:28 PM
jbettin jbettin is offline
straight 6 engine type?
I have a 1949 chevy 3600(3/4 ton) the engine is a staight six with overhead valves, which I'm fairly sure is not the original. I belive the 216 was the original engine which I thought was a flathead, but I could be wrong. someoney though it might be a 235 but I dont know. The only nubers I could find are on the passenger side of the crankcase behind the distributer they are B44 848 850
I'll try to get some pictures tomorrow but the valve cover is red with Chevrolet on it, the oil cap is in the center towards the firewall and there is a breather cap on the passenger side of the crankcase.
thanks
Old 12-05-2007, 04:08 PM
maxwedge maxwedge is offline
A990 racer
Re: straight 6 engine type?
Welcome to AF, what is the question, all Chevy 6's are overhead valve.
Old 12-05-2007, 04:37 PM
J-Ri's Avatar
J-Ri J-Ri is offline
I believe he is asking displacement.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 12-05-2007, 11:11 PM
Yeah displacement and approximate era. I thought the old Chevy’s had flatheads would that be incorrect? If so then this might be the original but I'm not sure. I’ve got one picture right now then my camera batteries went dead I'll try to get some more tomorrow, but I'm not sure how to upload it
Old 12-05-2007, 11:14 PM
SpinnerCee's Avatar
SpinnerCee SpinnerCee is offline
The Flathead is a Ford product, I don't think Chevrolet ever made one.
.:: DigitalMIX by djSpinnerCee ::.
Old 12-06-2007, 05:57 AM
A990 racer
Ford did make a flat head 6, Chevy didn't, I believe the 235 was an original truck engine back then and the 216 was the car version.
Old 12-08-2007, 06:21 PM
Ok I've found that the original engine was 216.5 CID in-line 6, so how can I tell if the current engine is the original or not, and if not how can I tell what type it is?
Old 12-10-2007, 08:18 AM
MrPbody MrPbody is offline
AF -Advisor
While similar in appearance, 216 and 235 are quite different. 216 was available from '38 through '53 in trucks. 235 was first in trucks in '41, through '62. If you could post a pic of the intake/exhaust, and where the side cover bolts on. I should be able to identify it for you.
Jim
Old 12-10-2007, 12:50 PM
I've got a few pics but how do I upload them?
Old 12-12-2007, 09:07 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
http://chevy.tocmp.com/models/engine.htm
If this doesn't help, I don't know what would. It may not get you to a "numbers matching" state but you'll at least be able to order the correct parts for your engine.
Bob
Old 01-31-2008, 03:14 AM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
i had a '53 6400 2 ton dump truck it was the 235 first year for hydraulic oiling in the top end
ran great
it was crazy to drive
two speed rear, a real dinosaur feel when driving it haha
is the oldest vehicle i have had so far
was in very nice straight condition too
paid 500 for it from a farmer out in the country, very minor rust only in one cab corner otherwise nice looking
dark blue original
i should have kept it, for parades and stuff hmm
haha
oh well
the 235 looked like any other ordinary straight six engine(L-6)
normal looking stamped steel valve cover as in the 60s and 70s and such,
flatheads in fords yeah, i had a 49 ford big 2 ton out here once but it wasnt mine
it had the flat head 6 in it still
very odd looking they are
my great uncle has a few very old tractors with flat head engines in them
i helped remove the cylinder head from one of them once
it got water in it and needs new cylinder sleeves
good luck!
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 02-26-2008, 12:05 PM
luxeryvic luxeryvic is offline
go to a site like tinypics.com and upload a pioc from your computer, you will be given a code with IMG at the beginning put that code in your post
