Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-05-2007, 01:10 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Just did a compression test on the talon
Well I just finished checking the compression on my talon and I was surprised. The compression was better in that near 180k mile car than it was in my eclipse.
cylinder 4 175 psi
cylinder 3 180 psi
cylinder 2 200 psi
cylinder 1 205 psi
Now I know N/A and turbo comression ratios are different, but should that matter with what kind of compression it puts out? I know my rings are done for in the talon cause it smokes, unless i put stop smoke or engine restore in, which i guess coats the cylinder walls and increases compression. Does it sound like I might need to look into that engine restore additive for the eclipse, in order to boost the compression numbers? Really so far thats the only problem I've encountered with the eclipse, and it still runs good, with no oil useage. Does anybody use oil additives with their turbos?
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 12-05-2007, 02:29 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Just did a compression test on the talon
I dont, usually oil addatives are very thick, not really want to want to be putting in a turbo car that relies on the oil to lube the turbo.
This compression test was for the 1.8? It doesn't look bad, not anything to worry about anyways.
How do you know for sure its the rings on the talon? Have you done a compression check on it yet.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 12-05-2007, 03:17 PM
Yes that compression test was on the 1.8L. I'm not positive that it's the rings, but I guess it could be the valve seals. I just figured that because the engine was so old, it was most likely the rings. I didn't do a wet compression test.
I just know on the GSX the compression numbers were significantly lower a few months back when I tested it. They all went up to around 160 after doing a wet compression test, so that leads me to believe its probably the rings (GSX). The 1.8's compression was higher on the dry test than the GSX's wet test.
Good call on the oil additive, I wasn't going to do it with the turbo unless somebody else had good luck with it. I was just trying to think of an easy fix to boost up the numbers on the gsx without tearing into the internals.
94 Talon 1.8L-SOLD
Old 12-05-2007, 06:39 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
I would try tightening the head bolts near cylinder 3 and 4 see if that boosts your compression....
That compression doesn't look to bad. Do you want to keep the car? You know you don't get much performance out of the 1.8L.
Old 12-05-2007, 06:49 PM
Holset powered 420a
I think the 1.8 is more of a DD for him.
Yea I guess it about time to look at a rebuild for the talon. It appears your in the same boat as me. I think its time for a 6 bolt swap
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-05-2007, 07:59 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
IIRC, wet compression tests on our cars are innaccurate because we don't have dome style pistons, so the oil just sits on the piston instead of "sealing" the rings.
95 Talon TSI AWD
97 Eclipse GST
Old 12-05-2007, 08:51 PM
Holset powered 420a
More oil FTW!! Add 1 quart per cylinder... That ought to up the compression... hehe
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-05-2007, 09:04 PM
Yeah the 1.8L is my reliable daily driver, I'm going to drive it until it blows up. I was just comparing the numbers with my GSX. It just seemed odd to me that, that old tired out engine had better compression numbers than my GSX. I was looking for a fix for the GSX rather than the 1.8. I might try your idea of tightening the head bolts though. Thanks for the advice
Haha, I don't think I'd waste my time doing a 6 bolt swap into the 1.8. But, if the GSX ever CW's (knock on wood) I'll be all over it.
94 Talon 1.8L-SOLD
Old 12-05-2007, 09:28 PM
Holset powered 420a
Yea thats what I was talking about. Keep the 1.8 as the DD but put a 6-bolt in the 2g
98 Eclipse GS Turbo
2001 BMW 325i - DD
