Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 12-04-2007, 10:33 PM
HoosierDrifter's Avatar
HoosierDrifter HoosierDrifter is offline
Rear Mount battery = NO CHARGING >:(
ok just finished rear mounting my battery and now it wont correctly charge while the engine is running. my gauges usually dont work after startup either... sometimes they will work if i start it up and quickly give it throttle. i used 2 gauge wire and directly soldered the extended 2 gauge into the positive side where it used to go into the battery up frt. my alternator crap? what else maybe? bad ground? not big enough cable??
71 Camaro RS/SR'ed 92 240sx
Old 12-05-2007, 04:29 PM
slideways...'s Avatar
slideways... slideways... is offline
Re: Rear Mount battery = NO CHARGING >:(
should be ok cable, id say check your alternator, check for a short somewhere, wiggle wires and stuff to make sure you dont have a break. as long as your battery is tied down properly, the system should run like normal. 2 guage is ok, it should work just fine.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
