Vacuum Pressure Testing
I would like to test my engine for vacuum pressure. I rented the tool. What can i do from there?
Re: Vacuum Pressure Testing
I don't know if this is TBI engine or a CPI engine. Either way, locate a vacuum port and connect your guage there, start the truck up and watch the gauge and record your findings.
It is a TBI engine. 92 S10 Blazer, 4x4, 4.3L Z.
Vacuum findings: Pressure at manifold intake: a steady 19. What is the measurement name? Any other tests I can do to make sure all vacuum is good? |
19-20 range is good vacuum.
It is called inches of HG inches of vacuum. Some gauges read in mm hg and some in g cm but I like it in of vacuum better. Most vacuum gauges have a green range for good and a red range for bad. lower vacuum inthe 15-17 range is late timing or a egr valve open or vacuum leak some place. A flickering vacuum reding is a bad valve amd a engine miss will lower vacuum. A good cat stopped test can be run with a vacuum gauge to . check vacuum at idle and then at 2000 rpm. If vacuum drops at 2000 under idle the exhaust system is restricted. Also a vacuum gauge on the dash can help get better gas mileage. Some older cars had one in dash for gas mileage improvement Keep it in the green 19-20 range for good gas mileage. I have had it bring gas milage up and over 5 MPG more. MT
