Go Back   Automotive Forums Car Chat > Jeep > General Discussion
Old 12-04-2007, 04:04 PM
luxeryvic luxeryvic is offline
Amc
since there is no AMC thing i decided to post this here
what would it take to swap the straight 6 in my 64 rambler to a small block V8? would i have to switch the tranny too?
Old 12-06-2007, 02:53 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Amc
Wow, a '64!!!
Not sure about that model, but every other discussion about engine swaps have these things in common:
1) motor mounts will have to be the same, or frame modified.
2) Transmission bolt up points will likely be different, so you'll probably have to swap that out.
3) It's certainly possible to swap in a V8, but resale value may go down and if you're not into fabricating and pretty handy in the garage then it may be more than you're looking to get into.
All that said, I'm a big fan of modifying the engine you have in the vehicle to get more power. What engine do you have in your '64?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 12-06-2007, 03:44 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Amc
The I6 can make some pretty good torque on it's own and with very little work surprise the heck out of people, all while having a nice tone to the exhaust.
But if you're dead set on swaping.... I was thinking about it at one point with my '68 199. I know there a little bit of difference in the few years, but I also believe the fender rails are mighty accomodating on the '64 as well. Again in agreeance with the laundry list of mounts and etc will need to be fabricated up, let's face it, stock style replacement parts are getting hard enough to find, let alone conversion pieces.
Oh, and there is an entire AMC section with a Ramlber sub.
Old 12-06-2007, 05:09 PM
Re: Amc
whay kind of work would i do to increase the performance of my 232 strait 6?
i was just thinking of an engine swap for more power
Old 12-07-2007, 08:38 AM
wrightz28's Avatar
Re: Amc
Offenhausen (sp? no coffee yet ) makes a intake manifold for a 2-4 barrel carb and some minor ignition & exhaust work is about all you need for a big difference in feel.
I'm working on the exhaust end and did the ignition, and my 199 still with a 1 barrel carter on it suits me fine, I have a Chevy 305/TH400 with no use that I was thinking of dumping, but as it sits now, I won't gain much after the work, let alone with the intake still to be done. BUT, the car has been outfitted with a 3spd Richmond and Javilen shaft & rear end too so a little different gearing than your standard Rambler.
Old 12-08-2007, 10:53 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Amc
The BEST place for American straight six performance parts is Clifford Performance. They have been around for decades:
http://www.cliffordperformance.net/
Their slogan 6=8 says it all
Old 12-12-2007, 06:48 PM
Re: Amc
where is the amc post i cant find it
Old 12-13-2007, 09:36 AM
wrightz28's Avatar
Re: Amc
http://www.automotiveforums.com/vbul...lay.php?f=1798
There you go
