Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-04-2007, 03:25 PM
scals37's Avatar
scals37 scals37 is offline
replacing timing belt
just went in to my local shop about getting a new timing belt, ive heard clicking during accelerating my car so i figured that might be the problem, hes gonna take it in tonight at 6 and look at it tommorow, he warned me that replacing the belt could be upwards toward $600??
i have never heard of a new timing belt costing that much, but he told me that due to the talon's engine, theyd have to lift it out and whatnot... what should i do?
1995 Eagle Talon Esi "I shall call her Eileen"
Old 12-04-2007, 03:30 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: replacing timing belt
Depending on what he is replacing that price may not be to bad. Its recomemded that when you do the timing belt service you replace the pulleys, tensioner, water pump, and the belt. Find out what he is replacing and let us know. 600 for just the belt is high.
You could do it yourself if you are mechanically inclinde some. I did mine without to much trouble. Took a solid day my first time. If you have the tools I would say go for it. Its not that hard.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 12-04-2007, 03:33 PM
scals37's Avatar
well, i might have tried if i was at home, but i am away at school, without a garage/tools and theres like 6 inches of snow, so thats out of the question... but are you saying that id HAVE to get all of those replaced? cause like i was saying, a timing belt alone shouldnt be that much
Old 12-04-2007, 03:37 PM
Holset powered 420a
How many miles are on the car? When I did mine at 60k I just replaced the belt. I would recomend replacing the belt and pulleys at the very least. Specially since your not doing the work, might want to throw a water pump on there also, if it goes out you have to tear the thing back apart since it would be right there.
At least find out how much more it would cost. All of these parts should cost less than 100.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-04-2007, 03:49 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
A timing belt is $75 itself so it'd be pretty hard to find the rest for $25. I'd say under $250 though.
95 Talon TSI AWD
97 Eclipse GST
Old 12-04-2007, 03:58 PM
scals37's Avatar
ill know for sure tomorrow, im gonna drop it off in an hour... but would he really have to pull the engine out to do it?
btw the engine has 70K on it, the water pump was replaced right before i bought it according to my the guy i got it from...
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Where is this? When I got mine from the dealer it was $125. Rape-age action there.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 12-04-2007, 04:01 PM
scals37's Avatar
do you guys think maybe i should take it to a chrysler dealer instead? this guy has worked on my current car and previous car, as well as some friends' in the past and has been somewhat reliable... but i dont know about this time
Old 12-04-2007, 04:30 PM
OEM Mitsu belt from SBR is $75.
A dealer would just rape you even more. And he doesn't need to pull the motor to replace the timing belt. And if they replaced the water pump already, my guess is that they also replaced the timing belt, so you shouldn't need to do it until it's got about 60k on it.
95 Talon TSI AWD
97 Eclipse GST
Old 12-04-2007, 04:34 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
First off, why would ticking mean bad belt? I've never heard this...
Second, $600 for a T belt job doesnt sound too bad to me. They bill probably $75/hr shop labor plus maybe $200 in parts so that leaves $500 for labor or 6 2/3 hours. If they can get it done in that time I'd say thats pretty good, I would take a good 12 hours or so to do a T belt myself, but I actually give a fuck about what I am doing whereas I bet any normal grease monkey doesnt.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 12-04-2007, 04:37 PM
kittay's Avatar
kittay kittay is offline
I've never once pulled the engine to replace a belt or any of the pullies. However, the timing belt is the only thing on my car I didn't do myself. I had Brendan do that. Making sure the timing is correct is very important, and I don't trust myself to do that.
But 600 sounds insane to do a timing belt!! But I've never paid shop prices for labor..
But Mitsu is the cheapest place for parts.
I don't think a belt would make a ticking unless one of the pullies is eating at the belt. I had that happen. Unless the belt was skipping teeth, but you would know that real soon (your car wouldn't be running now).. you may want to pop the hood and play with the throttle and listen to where the sound is coming from.
12.3 @ 112
12.5 @ 115
Old 12-04-2007, 04:41 PM
scals37's Avatar
alright well, what would that ticking be... only happens when accelerating from low speed to high.... usually around 2000 to 3000 rpms... i sprayed belt dressing on it to see if it would silence it, and it did for a few days, friend told me it was prolly the timing belt, so i took it to the shop to be looked at
Old 12-04-2007, 04:57 PM
You sprayed belt dressing on which belt? I hope it wasn't the timing belt, if you did, that belt is now ruined. The ticking noise could be anything. Have you checked for any exhaust leaks? An exhaust leak will usually tick under acceleration.
95 Talon TSI AWD
97 Eclipse GST
Old 12-04-2007, 06:26 PM
scals37's Avatar
well, the prick told me to bring it in at 6 when they closed, and of course i get there and some other guy says they have no room to hold it for the night.... SOOO i will be bringing it in at 8 tomorrow morning, afterwards ill have more answers
Old 12-04-2007, 08:14 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
The ticking could be alot of things, you might want to pin point the problem before you go dropping all your cash on things that don't need to be replaced. Like said above, and exhaust leak could be it. Is it coming from the engine compartment or from like the drive train? A worn CV joint will make a ticking noise when it is going out. It could also be lifter tick, which is very common in these cars. Both of my DSM's do it. Hell I've even read that one of the signs of crankwalk is a ticking from somewhere in the engine(probably that magnetic pickup hitting against the crank sensor). Most of the time a belt wont be the culprite. When is the last time your timing belt was replaced?
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
