Old 12-04-2007, 03:06 PM
gwjturner gwjturner is offline
1993 K1500 Misfire?
I have a 305 with 160,000 miles on it. I've kept the truck in near perfect condition since it was new and it runs near perfect as well. Well, almost perfect. When the weather turns cold (25 degrees or colder) and the engine is cold, it will start and run without any issues unless I try to accelerate to quickly within the first minute or so after starting it. The engine will act as though it is misfiring or intermittently starving for fuel. It's a TBI and this only happens within the first minute or so when it is stone cold. If I let up on the accelerator for not more than a few seconds, the misfire or starvation goes away and it runs perfectly from that point forward. Again, this ONLY happens when it's stone cold during cold weather. It NEVER happens when the engine is cold and the weather is warm. I just changed the MAP Sensor thinking that might be the issue but it wasn't. The fuel filter is new as well. (I change it every 15,000 Miles). I'm now thinking it might be the Fuel Pressure Regulator. Any ideas?
Old 12-04-2007, 03:43 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 1993 K1500 Misfire?
Check the fuel pressure first to make sure.
Check the spray pattern from the injectors. If at all uneven, run some seafoam through it. If equiped with a heat riser, make sure the actuator on it is working.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 12-04-2007, 04:28 PM
I did check the spray pattern on the two injectors and it is a real nice cone shape with no dripping. I've run injector cleaner with every oil change (3,000 - 5,000 miles) since it was new. The heat riser failed almost 6 years ago and I took it off. May be that's it huh?
Old 12-18-2007, 02:03 PM
Well, I installed another heat riser valve on the air filter housing and reinstalled the tube from the heat shield on the exhaust manifold. It's still stumbling when it's cold. I did make another observation though. When I press the accelerator far enough that it feels as though a secondary is opening is when it stumbles. I know there is no actual secondary on this TBI like on a carberator, it just feels like that extra burst. Any ideas?
Old 12-18-2007, 09:32 PM
1968 Pontiac's Avatar
1968 Pontiac 1968 Pontiac is offline
I had a similar problem with my 92 k2500 with 305. I replaced the throttle position sensor and that solved that problem.
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck)
1968 Pontiac Parisienne (rust free survivor)
1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck)
1989 Chevrolet K3500 RC/LB (454 & single rear wheels)
1991 Chevrolet Caprice Classic (police cruiser clone)
1992 Chevrolet K2500 EC/SB (almost rust free daily driver)
1998 GMC C1500 EC/SB
