Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 12-04-2007, 03:54 PM
jonnyblazer77 jonnyblazer77 is offline
Cool 93' Explorer blinkers not working
I have a 93' Explorer and the blinkers just stopped working, the hazzards work, so the flasher and the bulbs are good I think, also the lighted arrow in the dash does not light up any more either any help would be great.
Old 12-04-2007, 09:03 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 93' Explorer blinkers not working
Do the dash indicators work when the hazzards are working? If not, you may have a grounding issue with the instrument cluster.
Unfortunately I don't have the wiring diagrams for a '93, so don't know how much I can help beyond this.
-Rod
Old 12-04-2007, 09:45 PM
shorod's Avatar
SHO No Mo
I must have had a brain fart. Did you check the turn signal flasher? I suspect your '93 has a separate flasher for the hazard lights and turn signals. An open flasher would cause the symptoms you describe.
-Rod
