Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-03-2007, 08:02 PM
alapaha alapaha is offline
1996 k2500 w/ a 454 suburban easy question
heres my problem forgive me i'm sure this has been posted before.
it has a hard time starting just turns over. takes 3-4 times to get it going i checked the fuel pressure with the ignition on and it is at 0 psi. when i get it started the fuel pressure is at about 30 psi at idle. i pretty sure it is the fuel pump just want to make sure before i replace it.
thanks
Old 12-04-2007, 10:03 AM
maxwedge maxwedge is offline
A990 racer
Re: 1996 k2500 w/ a 454 suburban easy question
Welcome to AF, 60 psi is required
Old 12-04-2007, 02:45 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Check the pressure regulator. Removing the vacuum hose from it or pinching off the return line should increase the pressure significantly. If not, suspect the pump.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 12-04-2007, 06:31 PM
ok i replaced the fuel pump and am getting about 52 psi while running but when i turn the ignition on i still get no pressure till i start it up
Old 12-04-2007, 06:36 PM
A990 racer
How does it start with 0 fuel pressure at the rail, something is not right in the check out results. The injector poppets will not activate under about 58 psi.
Old 12-04-2007, 08:01 PM
i found a plug unplugged. i plugged it in now when i turn the ingintion on the fuel pressure goes up to about 50 then drops to about 10. once started it maintains about 50.
Old 12-04-2007, 08:46 PM
i'm sure it has to be the fuel pressure regulator but i can't seem to find it's location. anyone know where it is located?
Old 12-05-2007, 04:25 PM
A990 racer
Inside/under the upper intake plenum.
Old 12-08-2007, 05:14 PM
fuel pressure regulator was the problem. changed it works good
