Old 12-03-2007, 06:06 PM
mvette76 mvette76 is offline
distributer ??????
i have a 1345 code coming up on my truck replaced sensor went off for 6 weeks or so now back so i pulled the cap off to ckeck if anything was loose and i found that rotor has about an 1/8 turn play in it no side to side play just twist play is normal????
Old 12-04-2007, 10:09 AM
maxwedge maxwedge is offline
A990 racer
Re: distributer ??????
That is not the problem, the cam sensor to crank sensor correlation must be set using a scanner. BTW always post the year and engine.
Old 12-04-2007, 06:14 PM
777stickman 777stickman is offline
Actually a loose rotor on the dist shaft is one of the things to check for a P1345 code ('98 Service manual). Manual says if you can "gently rotate the rotor" and it turns (doesn't say how much) the dist needs to be replaced.
Other issues are: 1.) A loose CMP sensor. 2.) Excessive free play in the timing chain and gear. 3.) Distributor installed one tooth off in either direction. 4.) A loose hold down bolt allowing the dist to go out of time.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 12-12-2007, 04:42 AM
rlsc98 rlsc98 is offline
Question Re: distributer ??????
I have a 97 305 1500 and have replaced both of these sensors. do both sensors have to be put in"sync" with a scanner or does my ECM learn this on its own?
Old 12-12-2007, 09:19 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Timing and sensors are not adjustable.
But.
The dist sync has to be set with a engine capable scanner.
MT
