Alternator?
Last night and today, when I tax the battery really hard on my 1992 Buick Park Avenue (run headlights, radio, front and rear defroster, put brakes on which causes brakelights to go on, put turn signal on all at the same time- besides the radio, had to due to winter weather) my red "battery" light goes on. Once I stop any of these things (release the brakes, make the turn, etc) the light goes off. The light only goes on when I have all of these things happening at once. I purchased a brand new 5-year battery earlier this year, so it shouldn't be the battery. I'm thinking I need a new alternator- am I correct?
Re: Alternator?
no not really your loading the system.you could go & check out the system to see what the out put is.(13.2 -14.5)but if your doing this at an ilde(loading system)u may find its ok.
Re: Alternator?
Even with all the load put on at one time, it isn't normal for the battery light to come on at all. I would bet dollars to donuts the alternator is bad. Especially if you haven't changed it in a long time and the battery is good. You can pull the neg cable off the battery when it is running and if it dies, then the alt is bad. If not, then look elsewhere. This is an old school method, but rather easy to tell if the alt is charging or not.
Re: Alternator?
Knowledge can be communicated, but not wisdom! ![]() ![]() |
