Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-03-2007, 12:52 PM
jackass379 jackass379 is offline
Send a message via MSN to jackass379 Send a message via Yahoo to jackass379
Blower motor only works on high.
well a few days ago I put new plugs in my burb and accidentally bent the tang over on the heater core housing under the hood, the thing on top with like 3 wires going into it with a plug so I bent the tangs back up put the plug back on and now I do not havelow or medium fan only high any suggestions? oh yeah it is a 88 gmc suburban thanks guys
Old 12-03-2007, 03:52 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Blower motor only works on high.
Sounds like most likely the blower resistor is bad. Confirm that you have power to it from the switch, if you do, replace it.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
