Old 12-03-2007, 12:36 PM
twinmorr twinmorr is offline
Check engine light
Have a 1999 Ford Windstar and the check engine light will not come on when the key is turned on. Is this more than likely a bulb?
Old 12-03-2007, 01:19 PM
tomj76 tomj76 is offline
Re: Check engine light
Assuming the vehicle starts and runs, then yes, the bulb is the most likely culprit. I recently replaced all the bulbs in the instrument panel of my '96 Windstar, as several burned out. However they were only the ones that illuminated the cluster, and none of the indicator bulbs had gone bad. All the bulbs are the same. If the MIL was on for an extended time I could see that it would burn out.
Old 12-03-2007, 01:21 PM
Is it very hard to replace? The van starts and runs fine.
Old 12-03-2007, 01:23 PM
northern piper's Avatar
northern piper northern piper is offline
you know, I've often thought that IF my CEL light burned out would I take the time to replace it??
I wonder if this is a blessing in disguise
Old 12-03-2007, 01:26 PM
Problem is; in order to pass E-check it must be operational.
Old 12-03-2007, 02:33 PM
yep I know but I guess I'd just like a month to go by without another CEL code!
Old 12-03-2007, 03:19 PM
It requires that you first remove several pieces of plastic molding from the interior to expose the instrument cluster attachment screws. Mine has a mechanical instrument cluster, so removing the cluster required disconnecting the speedometer cable, which is probably the most difficult step. This requires that either disconnecting the speedometer cable intermediate joint inside the engine compartment (roughly on the driver side), or reaching up under the dash and disconnecting the cable from the back of the cluster (very awkward).
I believe the electronic speedometer is much easier to remove from the dash. Once it's out, the bulbs are easy to remove and replace.
Old 12-04-2007, 07:30 AM
Any idea which fuse i should check first? thanks for your help.
Old 12-04-2007, 10:36 AM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Hello
Dashes can be a pain to pull apart. However, once you've done one they're all very simular. The trim either pops off or has hidden screws. I usally pull/pry and try not to leave marks and not break anything.
Another thing to keep in mind that there are sharp edges inside of the dash.
I guess I'm saying experience is the best teacher.
Regards
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
