| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
trouble starting in winter
hey guys,
so its winter time and the part of the year my Eclipse hates the most. Anyway my car starts and runs Perfect in the summer but when it starts to get cold I can almost garentee it will do the following turn the key: Starts/dies instantly (giving gas does nothing) turn the key: Starts/dies instantly about 3-4 times then do it again and it starts perfectly any ideas why it would do this? |
Re: trouble starting in winter
Mine did that the one year I drove it in the winter. It could be you have too heavy of an oil weight that makes it start rough. Or something to do with the car being a turbo. Get a beater and put it away not worth getting into an accident in it IMO
![]() ![]() SOLD '97 GSX EvoIII 16g, FMIC shortroute piping, FIC 850's, DSMLink V2.5, 3" turboback, mbc, Walbro 190 rewired, autometer boost gauge, Tokico shocks/springs -2", Motegi MR7 18" hyper black wheels '05 blacked out f150 FX4 |
May have something wrong with the choking effect for fuel delivery and sensors not picking it up. Does it throw CEL's ? Have you recently changed anything that would effect its operation ? Check and make sure you have enough anti freeze as well , if the block is iced over it will cause yo uagreat deal of trouble.
2004 Mazda 6i 1997 Tahoe |
Mine does bad too starting up. It takes a try or two, and then idle will get low like it's chugging, shoot up and be fine for a little. Just have to let it sit and warm up for alittle. At least your battery doesn't drain itself for no reason during the winter... even with a brand new battery.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
Ya that's not true at all, and yes I am though. If the car doesn't move in a week when it's cold, the battery will die though. Car can sit for month in the summer and be start right up. And it's a brand new (last year) Die Hard with the max cranking power. Good times.
made me extremely mad after paying 200.00 for it.
I have an Optima battery and never looked back, however I doubt that makes a difference to your problem
It used to make a difference when they used glass insulators in the batteries between the plates because they would break and cause the battery to "leak" everything out through the floor, but now they use paper insulators so it shouldn't have gone dead faster one way or the other.
Batteries can lose 2-3 volts just from sitting in the cold. If not you may have a parasitic load that is draining the battery a bit over night, like a glove compartment light that stays on. Or like someone said above, it could be the type of oil you use. If it has a high viscosity it can make it hard for the starter to turn the motor over.
1993 Eclipse GS BONE STOCK?? Winter Project 07-08 Check out my page on cardomain: http://www.cardomain.com/ride/2955127 |
