Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-02-2007, 10:55 PM
Pantagonia Pantagonia is offline
1997 suburban starting the engine
I have a 1997 Suburban (1500) and it is having problems starting up.
usually in the morning it will take about 5-10 seconds before actually starting. After the first start of the day it is usually starts up with no problems.
is there anything i can check or something that i should look into to get it to start up right away?
thanks
Old 12-03-2007, 12:14 AM
tempfixit tempfixit is offline
Re: 1997 suburban starting the engine
thanks
Check your fuel preesure (cold) with a tester. SHould be 60 to 66PSI.
Do a search there are many threads with testing procedures.
Old 12-03-2007, 12:35 AM
how do you check the fuel pressure?
also, what would be the keyword for the search
Old 12-04-2007, 04:29 AM
Here is thread that explains it quite well by MT2500;
http://www.automotiveforums.com/vbul...essure+testing
Keyword for search is FUEL PRESSURE TESTING
There is a Schrader Valve on the fuel injector line (it has a black cap on it and resembles a tire valve stem principal)
Check with your local parts stores they may have one in their loan a tool program. (Checker, Autozone) If not Harbor freight has one reasonable price also parts stores have them for about $40.00.
If you do need to replace fuel pump use only AcDelco or Delphi fuel pump. Carquest now handles the Delphi pump
Feel free to ask more questions if necessary
Old 12-11-2007, 03:44 PM
How much would it cost to replace the fuel pump either through the dealer or a mechanic?
Old 12-12-2007, 09:29 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Fuel pump prices depend year and make on where you get them and the dealer or shop labor rate.
From 350.00 to 850.00 US $ is a good range.
But proper testing first to see what the problem is.
Low fuel pressure does not always mean the fuel pump is bad.
Also check tune up and fuel filter.
How many miles on the last tune up?
Good AC delco plugs?
MT
