Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 12-02-2007, 06:03 PM
Skippernoodle Skippernoodle is offline
1998 Explorer XLT Fan Motor
The fan motor on my 1998 Explorer XLT only works on the 2 highest settings. I have seen this with other vehicles that had a circuit board attachted to the fan motor causing this problem, is this the same with Explorers as well?
Old 12-02-2007, 09:49 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 1998 Explorer XLT Fan Motor
It sounds like, since you suggest you have discrete blower motor speeds, that you have the manual climate controls (knobs and dials). If that's the case, yeah, the blower motor resistor could be the problem.
The blower motor resistor is in a slightly different location depending on if you have a V6 or the V8, but in all cases, it's mounted in the blower motor housing accessed from under the hood. It will be screwed into the housing on the passenger side near the blower motor at the firewall.
-Rod
