Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 12-02-2007, 05:37 PM
jcase350 jcase350 is offline
Engine Question
Is there a way to check if Iam running on all 8 cylinders? I have a 90 Iroc 350 TPI. My idle is a bit rough and i'm not sure if it is a sensor or if i am missing on a cylinder. I have have a similiar problem in the past where i was running on 6 cylinders and didn't even know it until I took it to the mechanic. Any ideas or suggestions? Thanks
1990 Iroc-z 350 TPI
Old 12-03-2007, 12:12 AM
Morley Morley is offline
Re: Engine Question
Get it running and remove a plug wire. Does it get worse? If so, put the wire back on and move to the next one. Once you get to a wire that doesn't make the car run worse when removed you have found a dead cylinder.
Old 12-28-2007, 07:18 PM
sportlinetta's Avatar
sportlinetta sportlinetta is offline
Re: Engine Question
or a dead spark plug right?
Old 12-29-2007, 12:51 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Engine Question
yea, that's usually the cause of the dead cylinder. or an injector not firing of course.
Old 12-29-2007, 04:42 PM
Re: Engine Question
would that mean get a new cylinder or plug???
Old 12-29-2007, 04:52 PM
Genopsyde's Avatar
The President
Re: Engine Question
new cylinder lol. plug, wire, cap, injector, other ignition components. usually whichever fails the testing.
Old 12-29-2007, 08:45 PM
stepho stepho is offline
Send a message via AIM to stepho Send a message via Yahoo to stepho
Re: Engine Question
You can't get a new cylinder*, its part of the block. A cylinder is just the round hole in the block, that contains the piston. Fuel, air, and spark are injected into the top of the cylinder which drives the piston down. So if you have a dead cylinder it means its not getting either Air, Fuel or spark.
*technically you can get a new cylinder but you have to replace the entire block.
lol, u guys are dummmmmmmmmmmmb im 14 n i know more. i gotta 88 camaro.
Old 12-29-2007, 10:37 PM
Re: Engine Question
ok i admit i am learing. but i was thinking piston when i said cylinder
Old 12-29-2007, 11:02 PM
izzydjinn's Avatar
izzydjinn izzydjinn is offline
Re: Engine Question
get it running???????? , do you realize the shock this guy is going to get..... ....
Is.... peanut butter jelly time, peanut butter jelly time, peanut butter jelly time, peanut butter jelly time.
Old 12-30-2007, 04:16 PM
Re: Engine Question
it wont shock you. People have been doing this since the invention of the automobile.
Old 12-30-2007, 04:31 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Re: Engine Question
Thats what those little rubber boots are on the ends of the plugs wires, on my 2.8l camaro it had a bad miss, so i did this, ended up being a bad plug wire.
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 01-14-2008, 10:46 AM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: Engine Question
actually you are right, you can get shocked doing this, you just have to use common sense, when pulling on the boot, dont put your hand on something grounded, like the engine block, chassis, or ground straps. This is why mechanics sometimes buy a spark tool, it is actually a sparkplug shaped light tool, you plug into the plug wire, and then clamp on a ground, you can check for spark that way. but in my own opinion, it takes longer than just popping the boots off one at a time.
but i have been shocked by an HEI setup, and no, it was not fun, but it was my fault, if i had been smarter it wouldnt have happened.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 01-15-2008, 02:45 AM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
Re: Engine Question
dont worry tho, it wont kill ya... its just gonna hurt a bit. not nuff amps to stop your heart tho
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 01-15-2008, 09:43 AM
izzydjinn's Avatar
Re: Engine Question
Something like that jcase, but not exactly.......first, REMOVE a plug, THEN get the motor going, if it turns on then you got spark, if not then a plug, or a wire or the dist. cap is bad, but DONT get it running first because if its running and you remove a wire you'll get shocked and againg if you try and put it back.....WHILE THE ENGINE IS RUNNING
Old 01-15-2008, 09:47 AM
izzydjinn's Avatar
Re: Engine Question
Hey, thats right........I forgot about the spark tool that I have sitting on top of my craftsman tool box like every do it yourselfer has......right!!!
