Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 12-02-2007, 05:35 PM
toyotawolf762 toyotawolf762 is offline
no heat
i have a 92 4runner 4cyl. and im not getting very much heat..replaced the thermostat and rad cap and flushed the heater core..still the same..however i noticed that the rad has a small crack on top where the previous owner had repaired but it is still seeping out antifreeze..the radiator doesnt seem to be holding pressure cause when i remove the cap when its hot there is no pssft noise..nothing ...could this be why im not getting heat...temp gauge is normal..about half way...any help would be appeciatted
Old 12-02-2007, 06:30 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: no heat
I'm thinking you still should have coolant flowing thru the htr core. Maybe an air pocket is blocking the flow.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 12-03-2007, 03:33 AM
Re: no heat
your right...it does seem like coolant is going thru htr core...both hoses are quite warm...wherec would the blokage be ?..in the rad or core
