Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 12-02-2007, 11:54 AM
deesandvees's Avatar
deesandvees deesandvees is offline
What are these wires? (Pic)
This goes to the starter but are in need of repair. What are the black cylinders? Some kind of fuse? There is a number 16 on both of them.
Old 12-02-2007, 12:10 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: What are these wires? (Pic)
That is what's called a fusible link. You can't really repair that - you have to replace it.
The black cylinders are simply where the fusible link (orange wires) interface with the wires they protect (the larger red wires).
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 12-02-2007, 02:53 PM
So can I just cut the orange (fuseable link) wire after the black cylinder, get some new fuseable link wire and connector and butt connect it together then?
It doesn't look like I can open up the black cylinders. I want this all to be as clean as possible. Can I make my cut before the black cylinders and get new black cylinders that have the fuseable link coming out of them and are able to accept the red side too?
Old 12-02-2007, 06:48 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
I don't see why you can't just strip the cut wire ends, solder them back together. Use a piece of heatshrink tube to seal the deal, so to speak.
Old 12-02-2007, 06:54 PM
silicon212's Avatar
Confoundingly Lucid
A fusible link is a certain gauge wire at a certain length. When you mess with either, it no longer offers the same degree of protection.
When you splice the wire, not only are you effectively shortening it, but you're also effectively increasing its gauge, voiding it as a protective device.
Old 12-02-2007, 07:40 PM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
When a fusible link is bad, you can easily pull it apart by tugging on the wires. Try to get the same exact thing that you have. They always go in bad places, like behind the engine going down to the starter.. just like you have there!
Old 12-03-2007, 09:24 PM
So back to my questions, can I just cut red wire right at the black cylinder and butt connect new fuseable link wire of the same guage and length as the old orange wire?
Old 12-04-2007, 12:06 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Basically yes. I had a major problem with these in an old Ford van I owned 20 years ago. You can probably still buy these at your local auto supply store, especially if they carry the HELP line brand of products. They used to sell these in all of the available gauges, and like what was posted above you need to get the same rated gauge as what is on the vehicle. I remember there was instructions on replacing the fusible link right on the back of the package. If your local stores don't carry the HELP brand, they may offer another brand.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 12-04-2007, 02:29 AM
So the black cylinders aren't something special that I need to specifically replace? A butt connector will do the job?
Old 12-04-2007, 05:47 AM
bobss396's Avatar
The black cylinder IS the fusible link, that's what goes pop when you have a current surge. A good auto parts store should be able to match up what you bring them, NAPA has a good assortment of them. The #16 is probably for 16 gage, but go by what they prescribe. Some even come with the ring terminal on them.
Bob
Old 12-04-2007, 05:50 AM
bobss396's Avatar
Yes, a butt splice will do fine. Make sure that you get the right crimp tool though and some shrink sleeving to go over it. There are also solder sleeve types, you will need a heat gun (not a hair dryer!) to install them. Those I prefer over the crimp types, if you can borrow a heat gun and have the room to swing it, go that way.
Bob
