Old 12-02-2007, 10:54 AM
Akira31169 Akira31169 is offline
Idle issue
I have a 2000 Z24 2.4L 5 Speed Getrag man. trans. The car idels at about 1600-2000 RPMs. If im going down the road faster than 10 MPH and push the clutch in the RPM's will climb and hold at about 4200RPM and will not go to normal idle til it goes under 10 mph as im coming to a stop. I have changed the Throttle Position Sensor with no improvement. Any Suggestions?
Old 12-03-2007, 04:31 PM
spudracer73's Avatar
spudracer73 spudracer73 is offline
Re: Idle issue
sounds like a vaccum leak
AAS in Automotive Technology, and never stop learning!
Old 12-04-2007, 08:43 AM
Re: Idle issue
Any idea where to start looking (ie what component?)
Old 12-05-2007, 11:32 PM
shakewell shakewell is offline
Re: Idle issue
You should be able to just hear it. It will sound like a whistle of air. Check especially near the front of the engine.
Old 12-11-2007, 12:05 AM
Re: Idle issue
take a propane torch and turn the gas on a little, an run the gas around the manifold and the intake. if the engine revs up and smooths out then you found the vaccumm leak.
Old 12-11-2007, 07:09 PM
irregardless3 irregardless3 is offline
Re: Idle issue
if you don't find a vacuum leak, you can use carb clean to spray to find a leak.. you may need a ecm
