Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-02-2007, 03:19 AM
Christophe Salvain Christophe Salvain is offline
Engine ticking on start up
Hello
I got an engine ticking sound on start up.
It goes off after a minute when i think the oil is warm.
I change the oil (5W30) / swap oil filter but still the same %$&#! click click click !!!
Any advice is welcome.
Thx
Christophe Salvaing
Old 12-02-2007, 02:30 PM
maxwedge maxwedge is offline
A990 racer
Re: Engine ticking on start up
I'd suggest to start out with, as required post the year and engine.
Old 12-02-2007, 04:58 PM
Everybody knows I own a '00 Suburban 5,3l
Old 12-03-2007, 04:07 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Does it do it on warm starts too, or only cold starts?
If only on cold starts, you may want to try a crankcase cleaner and/or Lucas oil stabilizer. If that doesn't do it, either live with it or replace the lifter. Does the oil pressure guage read pressure while it's clicking?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 12-04-2007, 01:38 PM
Only on cold start. Never when hot.
I'll look at the pressure gauge tomorow morning.
Do you recommand a crankcase/lifter cleaner ?
Thx
Christophe Salvaing
Old 12-04-2007, 02:42 PM
J-Ri's Avatar
I would try a cleaner. No guarantee it will help, but worth a try.
Old 12-06-2007, 10:30 AM
Dont found lift cleaner online ?
Any url is welcome.
Chris.
Old 12-06-2007, 01:13 PM
OSUCowboy27 OSUCowboy27 is offline
Make sure you are using a good oil filter like AC Delco or Wix. Some of the "cheaper" filters allow oil to drain back. If you are using a good quality filter, you might try a full synthetic 0W-30 oil. Another suggestion is to use a quart of Rislone in place of 1 quart oil on you next oil change.
Old 12-06-2007, 05:06 PM
aztecf aztecf is offline
A can of Sea Foam ususally does the trick.
Old 12-06-2007, 07:06 PM
tempfixit tempfixit is offline
My preference cleaner would be SEAFOAM.
Old 12-06-2007, 08:45 PM
j cAT j cAT is offline
Originally Posted by Christophe Salvain
Hello
Thx
Christophe Salvaing
I had this problem when i got my 2000 sil 5.3l after the engine had 30,000mi the ticking at start up for 10 -40 sec then gradually dissappear. I put 3-4oz. of marvel mystery oil in engine oil no more than this amount. measure exactly too much is not good. if problem goes away lifters had debris or carbon causing them to drain off after shut down ususally over night.if this is the case change oil after engine has been driven several miles fully hot this will aid in debris removal when changing oil. never change oil when engine cold. you may have to repeat this for a couple of oil changes to clean up this containination. my ticking has not returned 110,000mi now..........
