Old 12-06-2002, 04:58 PM
QuickSilverEF9 QuickSilverEF9 is offline
Send a message via AIM to QuickSilverEF9
Cold start sensor?
My car has been really slow in first gear and has a very rough idle to it. When I push on the gas my car kinda trembles and accelerates slowly in short burst until i hit second and then everything is alright. After my engine is warmed up again it works just fine. I am changing my oil filter, fuel filter, spark plugs, oil and transmission fluid this weekend.. If this doesn't help what do you think the problem might be? I would lean towards my cold start sensor, my injectors, or possibly my fuel pump.
1997 Golf GTI VR6
-Leather Interior
-47000 miles
-JVC KDSH707 Head Unit
ON THE WAY
-2xInfinity Kappa Perfect 6.1 components
-12" Polk Momo sub
-JBL 600.1 amp
Future
-Brock B2 deep dish wheels
-Suspension.....
Old 12-07-2002, 12:23 AM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
Check your distributor... my car started doing that as my coil and ignitor were burning out.
Honda Enthusiast
Old 12-07-2002, 05:34 AM
MKS MKS is offline
it would only be the cold start sensor(5th injector or whatever) if u had probs starting it when it was cold i guess......
also u say it idles really dodgy .... does it ever stall if ya just leave it ?
1989 Toyota Supra 3.0i Turbo
150mph I think I'm nuts
Custom S/S Exhaust 5" Tailpipe
K&N Induction kit
Bailys Piston Dump Valve (WOOSH)
Wategate Shimmed by 5mm ummm boost
Old 12-08-2002, 11:58 AM
fiercecivic's Avatar
fiercecivic fiercecivic is offline
Send a message via AIM to fiercecivic Send a message via MSN to fiercecivic
Thumbs down
mine does the exact same thing! Not all the time though, just certain times. When it idles it almost is a "rumble" then when i hit the gass it bogs down for a while then takes off, this happens in almost evry gear i go into. And one time it did stall, it wouldnt start again.i cant figure it out either
Old 12-08-2002, 01:05 PM
I just replaced my spark plugs, did an oil change with a new filter, and changed the fuel filter. It doesn't bog down anymore. I had a massive amount of carbon build up on the electrodes of my spark plugs... It still idles kinda bad when it is cold though.....
1997 Golf GTI VR6
-Leather Interior
-47000 miles
ON THE WAY
-12" Polk Momo sub
-JBL 600.1 amp
Future
-Suspension.....
Old 12-08-2002, 04:20 PM
Thumbs up
ill have to do that too
Old 12-09-2002, 02:37 PM
i know what does it, on mine anyways. When i first start it, then drive its ok, but when i shut it off and start it again it idles all crappy and bogs down. Im gonna switch my feul filter, and see what happens
Old 12-10-2002, 12:02 AM
civicracer_1990's Avatar
civicracer_1990 civicracer_1990 is offline
Question
why would you be getting after it when its cold anyway??.........just wondering...or do you mean it does it with normal driving.......
"Faster and Faster until the thrill of speed overcomes the fear of death" Dr. Hunter S. Thompson
Old 12-10-2002, 03:08 PM
me? well it does it during all other seasons too.
97 S10 Blazer Hard Cold Start Problem Pilot423 Problem Diagnosis 1 10-14-2009 02:01 PM
93 Lincoln Town Car - Cold Start and Cold Run Issues blogsdon Town Car 1 08-14-2009 12:00 PM
96 Grand Am SE 2.4L Hard Starting Period Gman2007 Grand AM 2 04-13-2009 05:44 PM
location of coolant temp sensor/cold start timer 93 V6 fchanes Camry/Camry Hybrid/Vista 0 06-01-2005 12:16 AM
Poor cold start - faulty coolant temp sensor? ukrix Clio/Clio II/Clio III 1 02-25-2005 11:35 AM
