Old 12-01-2007, 09:15 PM
phewop118 phewop118 is offline
1-2 Shudder
The other day I was merging onto the freeway, up hill, at wide open throttle. Just as the transmission shifted from 1st to 2nd (at 6500 rpm), there was a sharp shuddering that I could feel. I watched the water in my water bottle jiggle with it. While it lasted for less than a second, it still makes me nervous. I have yet to have that happen again, but I haven't done too many WOT 1-2 shifts recently. Also, it definetly was not the pressure control solenoid, as subsequent shifts during that drive were fine. I have been suspecting a minor vacuum leak for some time. Is it possible that a it could cause something like this? Or would it more likely be that I could use some fluid in my tranny. BTW, its been 40k miles since the last tranny fluid change. Also, its an 01.
Current Cars:
2001 Oldsmobile Intrigue GLS 154k miles
2005 Chevy Trailblazer EXT LT V8 145k miles
2005 GMC Yukon XL SLT w/Autoride 86k miles
2007 Pontiac Grand Prix GT 77k miles
2007 Cadillac DTS Lux II 47k miles
In Limbo:
2003 Oldsmobile Aurora 4.0 - got side swiped while parked, waiting on insurance decision
Recent Past:
2007 Hummer H3 5-speed Lease was over 7/17/10
Old 12-03-2007, 06:08 PM
harmankardon35 harmankardon35 is offline
Re: 1-2 Shudder
6500 rpm in first? sounds like you just stole the car and the cops are chasing you or your TRYING to break something. Pull the codes out of the computer. Mine had a high rpm misfire that felt like a sharp shuddering in the tranny. I was sure the tranny was gone but it was just a simple misfire. Seriously if you drive your car like that all the time it wont last long. These are pretty good motors but their not small japaneese engines that can rev sky high.
Old 12-03-2007, 08:17 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: 1-2 Shudder
Apparently GM thought they could at least rev to 6500rpm safely, thats what they set the rev limiter at.
Im confident they could even go a scosche higher and not cause any trouble whatsoever.
I dont think youd ever really cause much harm to that engine doing that, the transmission is another story entirely.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 12-06-2007, 04:26 PM
Re: 1-2 Shudder
Yeah I figure as long as the engine isn't above redline, it's not doing any engine harm, but I do know these transmissions were not designed for the higher revving 3.5, so I don't let it get above 6000 rpm often. I think I'm going to have a pan drop and get the fluid changed in a month or so, about the same time I get the plugs done. Hopefully that will keep the transmission ok for a while to come. I really would like to get another 50k miles (I'm at 99k right now) out of the car without putting much $$ in for repairs.
Current Cars:
In Limbo:
Recent Past:
Old 12-07-2007, 06:15 PM
Jimmy Olsen Jimmy Olsen is offline
Talking Re: 1-2 Shudder
Yeah, I'm at 99k miles now myself and will change the plugs next Spring. Sure would like to get another 100k miles out of my old Intrigue without spending mucho $$.
Old 12-08-2007, 12:02 AM
LittleHoov's Avatar
Re: 1-2 Shudder
Sounds like a good time for both of you to change your transmission fluid if it hasnt been done before.
Old 12-08-2007, 02:27 PM
Re: 1-2 Shudder
I had mine done just before I reached 60k miles, but I am going to do it again and see if it helps with my transmission issues. As I wrote in another thread, my torque converter has been acting a bit weird around 60 mph with a part throttle load, so hopefully I'm just a little low on fluid. Anyone know if GM has released at any point along the way, any transmission/powertrain software updates that I could have my dealer apply to my car?
Current Cars:
In Limbo:
Recent Past:
Old 12-08-2007, 02:51 PM
Re: 1-2 Shudder
Transmission fluid changes at 40k and 75k. Probably will do another at 115k. The fluid looks very good and at 75k added a bottle of LubeGard. Every once in awhile I drive it hard in 2nd or 3rd.
Old 04-15-2008, 07:32 AM
BrokerSL BrokerSL is offline
Re: 1-2 Shudder
Just bought a 2007 base Grand Prix (3.8L / 4A). What is the typical mileage to have the 1st tranny fluid change? (Old 300m had obscure schedule, required one at 50k then every 25k there after).
Any horror stories with these cars as well?
Thanks.
Old 04-15-2008, 08:28 AM
dtownfb dtownfb is offline
Re: 1-2 Shudder
If you do mostly highway driving, you can go to 100k miles. I'm assuming you bought it used and not knowing how many miles are on the vehicle, I would change the fluid at 60k miles. Basically the car is one year old. It would have to have been driven very hard for the tranny fluid to deteriorate in such a short time.
Old 04-16-2008, 10:43 AM
panzer dragoon panzer dragoon is offline
Re: 1-2 Shudder
If you plan on racing your Intrigue you should expect more maintenance. At 6500 the rev limiter cuts the torque and shocks the tranny which is much more amplified in the lower gears. = cut the torque before the 1-2 shift, I personally tap the brake (1/10 sec~)before most high torque (not OD) shifts (4t65e)
Old 04-16-2008, 10:54 AM
Re: 1-2 Shudder
how many trannys can take balls out 6500 full power up/down shifts? - not many -. I like to downshift into 2nd coming off the highway all the time and even into turns.
Years of abuse by the 3800 club has made the 4t60/65e into a fairly robust unit.
Old 04-18-2008, 09:09 PM
Re: 1-2 Shudder
well in the past few weeks my tanny seems to be acting up as well. If i drive for a while (45 mins maybe) the tranny will slip and shudder in drive on take off, but it will lock up and take off just fine if I select a lower gear (1,2,3) just not D...Added a tube of lubegard antishudder, helped with the shifting but it still likes to shudder/slip in D only. Im thinking this is a TCC solenoid not fully locking up the converter or maybe im over heating a bit. Fluid still clean and pink. I think im just gonna avoid putting it in D until I hit the highway, take off in 3.
