Old 12-01-2007, 06:01 PM
steve blackmore steve blackmore is offline
ignition problem
99 lumina fans werent working had relays out was jumping to see if fans came on to see if relays were bad accidently was on the ignition relay got a small spark and now car wont turn over at all. checked all fuses they look good. i dont know what else to check. oh god what did i do sombody please help
Old 12-01-2007, 06:17 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: ignition problem
Check for burnt fusable link coming from the starter...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 12-02-2007, 12:12 AM
what is fusable link please explain
Old 12-02-2007, 06:45 AM
They use fusable links at the starter end of the primary ignition wires that go to the starter...these are wire with sections that are designed to blow like a fuse if overloaded...check for discolored insulation spots or sections that feel "noodly" because of the missing wire section inside...
If you find a bad one, simply get a replacement of the proper gauge from a parts store, cut the bad section out and replace by splicing in the new piece....
Check around the power distribution center and jump start terminal over the LF wheel near the battery too for damage....
Do you have interior lights, door chime, headlights, radio, etc?
...empty gun rack.
Old 12-02-2007, 08:40 AM
yes i have lights and everything on the inside is working on interior car just wont turn over. and im afraid to jump start a terminal thats how i got here so i didnt do something right i touched the wrong 2 when i pulled the relay.
