Go Back   Automotive Forums Car Chat > Toyota > ES300/ES330/Windom
Old 12-01-2007, 04:03 PM
1998GS300 1998GS300 is offline
Banging noise...frt/rear..
when i hit bumps i hear an annoying banging noise from the struts .. does it need struts or are the bushings gone? the car has 120k on it... thanks for your help
Old 12-20-2007, 11:37 AM
LexusWizKid LexusWizKid is offline
Re: Banging noise...frt/rear..
Most likely cause is the struts, but the best thing to do is always to get it to a shop to have tehm diagnose it.
Is the noise from every corner of the car?
Does it happen only over bumps?
As a general rule of thumb, most manufacturers recommend new shocks/struts every 60k or so as preventative maintenance.
If it is as bad as it sounds then there is most likely hydraulic fluid moisture on the strut assemblys themselves.
