Old 12-01-2007, 03:18 PM
Greg W Greg W is offline
1995 Windstar won't shift after running a while.
1995 Ford Windstar will shift when first started and then won't shift after it has been running a while. If it is shut off and then restarted it will shift for a while and then again stop shifting. Again another shut off and restart will make it shift. It is as if it is losing pressure after running a while. The fluid level is OK. I read somewhere that this trans has some sort of pressure compensator that changes pressure depending on temperature. I wonder if this is somehow related. I have a scan tool and there are no codes and the OD light is not flashing. It would be better to fix something simple rather than rebuild the transmission for more than the van is worth.
Old 12-01-2007, 05:13 PM
wiswind wiswind is offline
Re: 1995 Windstar won't shift after running a while.
I do not really know what to suggest....other than the Transmission Range Sensor (TRS) aka Neutral Saftety switch.
If this happens again....try shifting into '2' and see if that helps.
Otherwise, there was an issue, particularly on the '95 with the pump shaft....however, others have posted that a sign of this is a high fluid level (although you could be slighly low to start with...and the issue puts you up into the normal range).......but at this point....I am only guessing.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
