Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-01-2007, 11:44 AM
klvaleri klvaleri is offline
99 Killed
Hi Guys,
It happen to me last night when I slow down on a stop light my 99 Rodeo kill on me, pull over and put it in nutrual restarted and run fine. It also happen to me on a few days ago when tried to park. I am wondering where should I start to look at since it run fine now. Please help me with this one. Thank in advance.
1999 RODEO LSE 4WD V6 3.2L
Old 12-01-2007, 03:06 PM
Ramblin Fever Ramblin Fever is offline
Re: 99 Killed
Could be anything from bad gas to bad spark plug, loose spark plug, clogged fuel filter, etc....
I would start with the question of whether or not you've stopped for gas at a station you don't normally use; OR a cheap gas station??
Had this happen on me last year at King Soopers gas station....used it a few times without issue, then suddenly one day, out of the blue, truck just flat stopped running AT 65MPH ON THE HIGHWAY! Talk about frightening.
Stopped and picked up some fuel system cleaner, filled her up with Shell gas - what I had always used before, and hit the road....truck was good as new within matter of minutes.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 12-01-2007, 08:06 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 99 Killed
Mine has done that twice, and both times it was a bad intake manifold gasket.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 12-03-2007, 11:16 AM
mapua82 mapua82 is offline
Re: 99 Killed
Classic! Intake manifold gasket leak.
'99 Rodeo SLE 3.2L V6
'01 Camry CE 2.2L
Old 12-11-2007, 08:06 AM
Re: 99 Killed
Hi Guys,
My truck just died on last night again when I exit a freeway and CEL came on, brought to AutoZone and here is code they found P0101. Can any one tell me what is this code for. I hope some thing small went wrong with it. Thanks.
Old 12-12-2007, 09:43 PM
kellercars kellercars is offline
Re: 99 Killed
I don't know what exactly the code is but the P01 part tells you its Powertrain, Generic, fuel and air metering. I just wanted to say that I had a 99 rodeo that would do this a couple of years ago. It started out innocent enough and eventually would not restart. I learned to get out reach my arm up by the right rear wheel and yank the wires going to the fuel pump. It would always remedy the problem. Of course I eventually yanked too hard as the problem got worse, and I got frusterated. Eventually I got a whole new tank with a fuel pump from a junk yard and replaced it all including the last six inches of wire and the plug. Fixed it like new. Thats all I know.
Matt
Old 12-12-2007, 09:46 PM
Re: 99 Killed
OOps!, I meant LEFT REAR WHEEL, sorry.
Matt
