Old 11-30-2007, 09:38 PM
Asu Asu is offline
Clutch Fluid???
I was wondering if there was a specific type of clutch fluid i had to use.
Old 11-30-2007, 11:43 PM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Re: Clutch Fluid???
Same as brake fluid.
Old 12-02-2007, 01:22 PM
Asu Asu is offline
Re: Clutch Fluid???
I filled up the clutch but i still of no pedal. When i push in the clutch theres nothing. Is this because of air in the clutch line when i disconnected it.
Old 12-02-2007, 09:11 PM
AlohaBra's Avatar
Re: Clutch Fluid???
You need to bleed it from the slave end.
Old 12-03-2007, 01:18 PM
4x4grey88's Avatar
4x4grey88 4x4grey88 is offline
Re: Clutch Fluid???
Can you give more information?? It was the indication that the fluid was only low and now clutch is not working at all??
The clutch hydraulic system is self venting, so if you pump the clutch a couple times and you still have no pressure to disengage the clutch it might be time to replace the clutch.
How many miles are on the Jeep?
The clutch hydraulics system can also be replaced as a complete system for about $125.00 (e-bay sells full fluid, ready to install) and is very easy to replace. Just a couple bolts to work with.
www.jeepforum.com; www.socalultimate4x4.com
1998 Wrangler (replaced my 88 XJ)
21' Mini Winnie (replaced my Pace Arrow)
Old 12-03-2007, 09:42 PM
Asu Asu is offline
Re: Clutch Fluid???
The clutch was working fine until we lost oil from the line by the tranny. We refilled the resovoir but still have nothing at the clutch pedal.
Old 12-05-2007, 07:58 PM
DOCTORBILL's Avatar
DOCTORBILL DOCTORBILL is offline
Geo Metro Lover
Re: Clutch Fluid???
See "Asking for an opinion" by me in this Forum.
Does your problem resemble mine?
If I fill the reservoir and then pump the pedal like a crazy man, it comes back until
enough slowly leaks out again- from the Throwout Piston seal (17 years old) to cause a dead pedal.
Doctor Bill
