Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-30-2007, 09:07 PM
blackEyeSSFly blackEyeSSFly is offline
Blown Oil Line
buying a 350 for 200.00 dollars problem is it has a blown oil line and has been sitting for about 3 yrs...Im replacing and upgrading many parts anyway but is the oil line a huge expensive problem, im thinking because the engine is already pulled and going under surgery that it should not be a problem? Somebody help..
Cardomain http://www.cardomain.com/ride/2143750
Success is to be measured not so much by the position that one has reached in life as by the obstacles which he has overcome
Old 11-30-2007, 11:17 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Blown Oil Line
Go ahead and explain a little more about this 'blown oil line'. The oil line would connect the engine with an oil cooler near the radiator, it's not internal to the engine.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 12-01-2007, 12:01 AM
Re: Blown Oil Line
Ok i talk to they guy and i asked him exactly whats with the oil line and responded with this...
I blew an oil line. My dad "fixed" it, told me to drive it, it didn't run right so I made him drive it, he said he couldn't get it over 75 so he parked it. He pulled the motor a year and a half later and there were metal shavings in it. Other than that I am not sure. I wish I could help you more.
Old 12-01-2007, 01:38 AM
silicon212's Avatar
Confoundingly Lucid
Re: Blown Oil Line
Metal shavings?
Rebuild time.
Old 12-01-2007, 01:12 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: Blown Oil Line
Oh yeah, the engine's defianetly shot.
Old 12-03-2007, 07:26 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Re: Blown Oil Line
Figure that you're in for at least a reground crankshaft and the bearing saddles and rods should be checked carefully. A line honing or boring may be required if a main bearing spun. Count on going for a good hot tanking and hand cleaning. If you have another block candidate, pass this one up.
Bob
