Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 11-30-2007, 03:56 PM
bert5 bert5 is offline
Question 2003 impala gas mileage
had intake manifold(plenum kit) replace by my mechanic due to an antifreeze leak into the old one. 3.8l 231 engine-- before replacement was getting 26-27 mpg average- the day after repair i am getting 19-20 mpg!!! mechanic does not know what problem is if engine idles and there are no warning lites,etc.
Old 11-30-2007, 07:07 PM
maxwedge maxwedge is offline
A990 racer
Re: 2003 impala gas mileage
Welcome to AF, what is "if engine idles"?, second some systems will relearn after the battery was disconnected, give it some time.
Old 12-01-2007, 05:01 PM
Sorry about the error----Mechanic says everything is normal--engines idle and timing were set properly after replacing upper plenum kit!
It's just amazing to me in the decrease in gas mileage after what he said was a simple repair procedure. Is there something he is missing????
Old 12-01-2007, 06:36 PM
A990 racer
Any drastic drop in fuel mileage has to come from an error in a sensor input or commands from the pcm, usually this will set a code, one other possibility is the cat is beginning to fail, a back pressure test at an O2 port would reveal this issue, but it is usually accompanied by a loss of high speed power.
