Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 11-30-2007, 03:50 PM
jveik jveik is offline
any ideas on torque specs?
anyone know what the torque specs would be for the following on a smallblock engine with turbo 400 tranny?
the 2 large engine mount bolts that go through the rubber part of the mount
the four bolts that hold the plate that the mount rests on to the frame rails
the two transmission mount bolts that go through the crossmember under the tailshaft of the transmission
any ideas? I was thinking that it was a "get 'er good and tight" situation, but i just want to make sure before i overtorque anything
Old 12-05-2007, 05:44 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: any ideas on torque specs?
Yeah, just get 'er good 'n' tight
I've never had a problem using an impact wrench with a max torque of 500 ft.lbs. I don't think you're going to break bolts that big by hand, if the metal bends, you're tight enough
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 12-05-2007, 06:51 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
I just tighten them up to 50 lb-ft. 35 lb-ft on the transmission mount bolts. Good and tight to the point they won't work loose, yet won't damage anything.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 12-10-2007, 07:51 PM
cool beans
thanks
