Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 11-30-2007, 03:12 PM
hulkmn069's Avatar
hulkmn069 hulkmn069 is offline
1999 Rear end help please
I'm on line trying find a rebuild kit for the rear in my 99 and can only find 98 and down for the ring and pinion. does anyone know if the 98 setup will work or not. thanks
Old 11-30-2007, 08:46 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: 1999 Rear end help please
Yes the 98 will work.
All you need to know for the ring an pinion is your gear ratio (5.54, 3.73 etc.) and what axle - it is probably a DANA 35.
here is a rebuild kit for a dana 35 from summit that will work on your WJ... http://store.summitracing.com/partde...5&autoview=sku
did you just want the rebuild kit or the RING and PINION Gears as well?
here a ring and pinion (3.73 gears) http://store.summitracing.com/partde...5&autoview=sku
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 11-30-2007, 11:16 PM
hulkmn069's Avatar
i am getting a 35 kit for a 98 dana 35 and going from a 3.55 to a 3.73 and all the bearings and what not from four wheel supply so i was nervous but if it fits i'll be happy
