Go Back   Automotive Forums Car Chat > Mercedes-Benz > C-Class
Old 11-30-2007, 12:56 PM
ricedarian ricedarian is offline
brakes
I need new brake pads for my 94 C class...anyone here of any good sites that offer these..hopefully a mercedes specialist..I have come across one site has anyone heard of http://www.myhotmercedes.com/mercedes_benz_parts/Brakes if so what do you think or do you have any suggestions?
Old 01-18-2008, 09:15 PM
rarthompson rarthompson is offline
Re: brakes
if you don't mind squealing get aftermarket pads. if you do, get original mercedes pads.
1988 Mercedes Benz 190E 2.3
Old 01-19-2008, 12:10 AM
G.A.S. G.A.S. is offline
Re: brakes
You can get these right at your local parts store. just make sure to tell them you want the top of the line pads.
Squeeking would come from the pad being loose in the caliper and that is what that goop they give you with the pads is for. You have to clean your caliper where the pad rests and also the lip of the piston. apply there goop (I myself like to use the black RV cylicone) to the pad and its resting points, install the pads and then finish the job. Pump up the peddel untill it is hard and now let it sit over night and let the cylicone dry.
the two most important factors to keep no squeek breaks are.
#1 clean pad resting points.
#2 Let the cylicone dry.
Squeeling brakes is from a glaze build-up on the rotor
Old 11-19-2008, 08:48 AM
bobby1978 bobby1978 is offline
Banned
Re: brakes
i suggest you to go on unauthorized advertising link removed by Moderator. :-)
Old 12-12-2008, 12:23 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: brakes
Please check the date of the last post in the thread and do not respond if that date is longer than 3 months from the current date.
From AF's Community Guidelines:
POSTING IN CLOSED OR OUTDATED THREADS:
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
The link to these guidelines can be found here:http://www.automotiveforums.com/vbul...uidelines.html
Closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
