Battery Kill Switch Needed - 94 'Burb
I'm tired of pulling fuses, checking battery drain issues etc. and it's getting that time of year where I hate working on cars. I have a battery drain issue (posted somewhere on here), that I give up on, lol.
At work, I manually pull the neg cable off the battery, just for the sake of kepping it from draining. (its a slow drain, dead in 7 days if the car isn't driven). I don't mind setting the clock/presets, so what I want to do, so I don't have to pop the hood and turn a wrench.. is install a switch. A battery kill switch. Searching the net, I see the same one on the heavy machinery I drove at the mill (50 Ton Euclids). Do I use the NEG cable and would that be ok to have that much length of cable going to the glove box? Right now, I believe the neg is grounded at an intake bracket, so if I put the switch in the glove box Id probably need like 3 foot of cable (ground to switch then switch to battery). Its not a security issue.. I doubt anyone would steal it if the keys were in it, lol.. I just want an easier way of killing the battery than poping the hood. Suggestions? edit.. here's one I had in mind What size cable would be recommended? |
Re: Battery Kill Switch Needed - 94 'Burb
If so you could hook it up on the neg cabel for a battery disconnect. MT
Did you? |
You might try getting a starter solenoid for a Ford. Just mount it near the battery, and run the small wires inside the cab. I always get nervous runing un-fused wires through sharp sheet metal.
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
It did control all the inside lights, dome, cargo, glove box etc. At night, when I can see the lights if lit.. none were lit. None were 'stuck' on. I gave up on finding the faulty circuit or whatever until the weather gets a little warmer.. so for now, I just want the kill switch. Like what kind (to handle the load without melting) Bigger cable? (to offset the length I need to mount inside the cab and reach the battery) And any other info that might help. I know its pretty straight forward, but I don't need a melted cable or switch to burn down the burb, lol. As per J-Ri.. I thought of that because I once had a 78TransAm and the headers caused excessive heat to the starter (causing hard starts when the car was warm). I bought a remote solenoid and mounted it on the fender well and all was good. But as for this vehicle.. I'm going for the cheapest cost and the least time to install.. so that means some cable, a switch and one side post. I just want to get the right stuff. |
What ever you go with I would keep it under the hood close to the battery.
If you use the solenoid setup mount it on fender or close to battery. And just put switch in cab. Some of them have to be grounded to work. Also I am not sure how long they would last switched on all of the time. But it might be best just to find the short or battery drain problem.
Or am I over thinking this whole situation, lol. I know the right way is to find the short/problem, but right now, that isn't an option. I need a quick temporary fix that doesn't require me opening the hood every time. |
I ended up with one similar to this. About $23. 4 gauge wire (7 foot), 3 copper connectors and a new side post. Got everything for about $45.
Now I have to wait for the neighbor to get home.. the guys at NAPA said to solder the cable into the connector, crimping is next to impossible with those type of connectors. Neighbor has solder, I didn't want to buy any, lol. Good thing my Steelers don't play until Sunday night.. this might have to wait until tomorrow. |
Quick question.. more like a dumb question.. I installed this type of switch..
![]() I used both posts (on the back of the switch).. one post from the battery (NEG) the other to the motor (ground). When I connect the battery, both positions of the switch give power to the vehicle. Should I be only using one post on the back of switch?? I reversed the ends and got the same result. |
If it is a on and off switch ground should only go threw it in on position.
Did you get any instructions with the switch? Does the battery neg cabel have a body ground wire on it close to battey post anywhere?
Heres a real quick crude diagram of how it is now. ![]() should it be like this instead? ![]() eidt: Is the body ground needed? Any drawbacks if I leave it off? |
You will need to wire the switch to break all grounds. Remove the neg ground cable from batter and Run a cabel from neg battery post to the switch. Then another cable from switch from the other post on switch back to the origional battery neg cabel.
The second image is how it needs to be (and is how your instructions say to do it). Is the body ground really 'needed'? If its absolutely needed, I can ground anywhere on the body? Because Im really not to keen on buying anymore wire and I think (I hope) the existing body ground wire should be long enough to reach from the switch to somewhere behind the glovebox. |
