Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-30-2007, 01:07 PM
poormillionaire2 poormillionaire2 is offline
Tranny Issues
My tranny isn't performing like it used to. I noticed at WOT, it doesn't shift when its suppose to (especially 2-3) (A4: 4L60E). It hits the rev limiter a few times and then finally shifts when it let off a little on the throttle. Under normal driving, the tranny works fine. Shifts fine, doesn't slip, and is still smooth. Another thing is when I manually downshift into a lower gear, my RPM's go down like I am in neutral and rev freely until I hit the RPM that it needs to pull the car. When I used to do this, you could feel the motor wind down when I put it in a lower gear. You could basically 'feel' the torque waiting there to be unleashed) And then the throttle response would be incredible. But now, it feels like its in neutral until a certain RPM. It has barely over 102K miles. What could it be? Could a broken tranny mount cause this abnormal operation? Do you think some much-needed tranny fluid could be the problem?
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
Old 11-30-2007, 01:53 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Tranny Issues
First, the common question to start answering your question: what' sup with the fluid? (color/level/smell)
At 102K the filter and fluid should have been about 20k ago. IF, and I mean IF the fluid is brown and silty looking you could do a filter and fluid swap (replace a qt. of ATF with lucas) and you might get lucky.
On the other hand, if the fluid looks and smells like the bottom of a pot coffee that's been on the burner for a bit, you'd be f-u-b-a-r.
Old 11-30-2007, 02:37 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Tranny Issues
does it have a tv cable too?
Old 11-30-2007, 03:42 PM
wrightz28's Avatar
Re: Tranny Issues
neh, 4L60E uses input from the VSS.
Old 11-30-2007, 03:57 PM
Genopsyde's Avatar
The President
Re: Tranny Issues
ok, looks like I have no suggestions to offer then.
Old 11-30-2007, 08:47 PM
Re: Tranny Issues
Ok, well I'll check the tranny fluid in a couple days when the weather is not so wet.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 12-03-2007, 04:34 PM
Re: Tranny Issues
So, I just checked my tranny fluid. It looked dirty, just like engine oil after 3K miles. Didn't smell like much until I practically put it on my nose. Can't describe its scent though. Should I get it changed and see what happens or is it already fucked?
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 12-05-2007, 12:36 PM
wrightz28's Avatar
Re: Tranny Issues
doesn't sound promising.
Old 12-06-2007, 06:43 AM
Re: Tranny Issues
Damnit, that's not what I wanted to hear. Well, there are a couple transmisison specialist shops in my area. I guess I'll try one of them. I think I just might wait until next spring because I am getting ready to put the car up for the winter. No sense in doing all of this just to put it up for awhile.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 12-06-2007, 09:57 AM
wrightz28's Avatar
Re: Tranny Issues
Well, it's a crap shoot. You really need to determine if it's gritty, if it is, that's the friction disk material from your clutch packs floating around in the fluid, not where it belongs, but at least it's there, BUTonce you crack that pan open and that fluid is gone, so is the material and inevtiable failure not too far behind.
It's your call and you know how it's been driven. Me , I would go forth in sin, with nothing to lose, the miles aren't that high on it, and if there just a hint of grit, that's normal, and I would add a bottle or so of a ATF anti-slip additive like Lucas. The transaxle on my Buick was toast, and I mean burnt ass toast, when I bought it, and I got about a good 2 years out of it before I had to overhaul it completely. That said, if you decide to go forth with it, I would not concider it "fixed" when it's all said and done and shop around for a long term solution
Old 12-06-2007, 04:55 PM
Re: Tranny Issues
I checked it twice and didn't see any grit or dirt in it. It looked debris-free to me. I think that's why I think that all it needs is a fluid flush and fill. But I checked the website of the shop I was considering and they do a free diagnostic check of all the components and a road test. So, I may look into that, well, because its free. And at the very least I can get the fluid and filter changed out. But if they don't have good news for me, the car is gone, sad to say. This particular car has been a lot of problems for me over the last few years or so.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 12-06-2007, 04:57 PM
wrightz28's Avatar
Re: Tranny Issues
Dude, do it yourself I wouldn't wnat a full on flush anyway at this point.
Old 12-06-2007, 05:43 PM
Re: Tranny Issues
I honestly don't know how to do it myself. Never have done it before. I know I have to drain it from somewhere, but where? And where do I pour the fluid back in? And...where/how do I change the filter? If I can answer these, I will try it myself next spring.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 12-07-2007, 09:43 AM
CamaroRS92 CamaroRS92 is offline
Re: Tranny Issues
I think that this is the most sensible approach. Have it checked out by a professional - that way you know exactly where you stand and what needs to be done. It will likely cost you less in the long run anyway to just have it done right and forget about it
Old 12-07-2007, 10:06 AM
wrightz28's Avatar
Re: Tranny Issues
Been seeing alot of folks getting raped by trans shops lately (self included), so maybe I'm being biased.
