Old 11-30-2007, 03:47 AM
collinsc148 collinsc148 is offline
Minor Electrical Quest.
When the vehical is sitting the pwr volt meter like to flucuate from 14 to almost the red zone on not enough pwr. what do you think may cause this?? maybe a alt going bad??? new battery or think that might be goin bad also or maybe just need to go bigger??
Let me know thanks
Old 11-30-2007, 10:35 AM
maxwedge maxwedge is offline
A990 racer
Re: Minor Electrical Quest.
Have the battery, cable connections and loaded alternator output tested, normal diagnsotic steps for this problem.
Old 11-30-2007, 03:23 PM
J-Ri's Avatar
J-Ri J-Ri is offline
I would confirm the guage on the dash is correct first, then do what maxwedge said.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
