Go Back   Automotive Forums Car Chat > Buick > Regal
Old 11-29-2007, 07:33 PM
richerd76 richerd76 is offline
1994 regal 3.8 problems starting and stalling
My regal clicks once when I try to start it. The battery gauge reads about 10 volts during this process. If I keep trying the car will eventually start, but the once running it will randomly shut off. I commute about 1.5 hours one way and it seems like the stalling goes away after about 30-45 mins in. I also noticed that the battery gauge will sometimes read 10-11 volts and then some times the gauge will read 13-13.5 volts. These problems all started right after I ran the car out of gas, mabye related, mabye not. The car has 220,000 kms on it and it hasn't gave me any trouble. I welcome any comments or questions that could help me on my quest.
Old 11-30-2007, 07:11 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 1994 regal 3.8 problems starting and stalling
Welcome to AF!!
The first thing to do is to check the wiring to the battery and the grounds. Start at the battery and clean the terminals. This sounds like you have an intemittant contact somewhere and you will need to track it down. The fact that it charges sometimes and not at other times indicates a wiring issue. It is possible that this is also causing the stalling problem. If you ignition loses power from the battery it will shut the car off usually due to voltage to the fuel pump dropping out. Give it a try and let us know what happens.
Old 11-30-2007, 08:32 AM
by checking the grounds you mean chassis grounds or the ground cable from the battery, probably both i guess...do you know how many possible ground connections there are? locations? is there certain circuits that I should be concentrating on?
Old 11-30-2007, 01:41 PM
Pontiac Guy
The main ground connects to the engine and would be the first place to start. I don't know exactly how many grounds your car actually has but this is the most important one. I suspect either the grounding point is rusted or the wire itself is bad. The other issue is the connections to the battery. They too can get corroded and cause issues. They are easy to clean. Try these and if it doesn't help post again and we'll see what we can do to help you out.
Old 11-30-2007, 05:09 PM
I replaced the starter, and discovered that the terminal was loose....(the nut on the inside). The car seems to start fine now but it still shuts off randomly. could it be the fuel filter perhaps?
Old 12-01-2007, 02:10 PM
stripe stripe is offline
when it shuts off. Do you mean all power? or just stall?
Cheers
Stripe
Old 12-01-2007, 03:56 PM
it just stalls, and then i can restart it; every time
Old 12-01-2007, 10:02 PM
are all your wires good as well as the plugs?(do you have to use a bit more gas etcetra)
Cheers
Stripe
Old 12-02-2007, 10:05 AM
actually late last night I discovered that i have a small gas leak. it was discovered when I went to change the fuel filter. so,i will fix the leak and then try it again.thanks
Old 12-02-2007, 09:11 PM
changed the filter and fixed the leak and the car is still stalling intermittently.
Old 12-03-2007, 07:16 AM
Pontiac Guy
Change the Crank Position Sensor, this is a common issue and can cause intermittant stalling.
Old 12-04-2007, 07:51 AM
where would I locate that on my car? I had another friend tell me that it could be a faulty starter relay, that looses contact randomly, is this possible.
Old 12-14-2007, 01:01 PM
thank you for all your help, I replaced the crankshaft sensor and it hasn't stalled since.
