| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
My 95 Altima (altima forums are no good) will not go into reverse. Its not that it won't stick, its like freaking blocked. All the other gears are fine but the reverse is useless. I can push my car backwards in neutral but I'm out of ideas, fluid level is good. Never had symptoms before.
Its not a DSM but I need you guys.
'98 Contuor SE, 2.5 V6 Auto Silver '08 Altima 2.5S, Auto Super Black |
Re: No reverse on 5spd.
Try to put it in reverse with the car off, then push the clutch and crank it up to see if it works.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
Sounds like a broken slider.
2004 Mazda 6i 1997 Tahoe |
already tried that silver, its like blocked off. i tried everything except dissmantling the tranny. it just happened an hour ago and its raining.
HELP!!!
Dude , your reverse is shot...
Dam nit what does that mean man? What do I do about it, fixable?
Once a gear is gone , there is no easy fix. It's rebuild or buy a used one.
It's most likely that the tranny is shot, but not necessarily. On my buddies 5-spd 420a, we pulled the tranny apart to work on some rattling issues and when we put it back together, we fucked up these little copper "bushings" that the gear rails slide into. So I pulled the tranny back apart and put new bushings back it it and the tranny shifted like new. I'm not sure if that's your problem, but I know when we did that with his, the car would simply not go into gear, either running or shut off. So maybe you should try tearing the tranny apart and checking those out, if the altima trannys' have them. IIRC, it was a relatively easy fix, it was just time consuming.
Is it gonna be the same though, i mean it doesn't look or feel like the shifter uses cables. I can't see it right now but I only took the boot off and some panels. If I can get to them should I replace the bushings?
Yeah, its night time now. Whats the name of the part so I can try and get it tomorow?
Don't go randomly buying parts until you are certain what the problem is. Trouble shooting across the internet is difficult enough and now your talking internal transmission diagnosing so we're giving scenarios and ideas of what could be wrong...some crooked places like autozone have a no return policy one some items as well if opened so...
OK, well tomorow I'm either gonna open it up myself or have a cousin of mine do it. This blows man, whats the probability I'll f*ck something up in there.
Nothing if you just remove the housing pieces to 'look' if there is something broken in there , youll see it as most likely little metal shavings all over , little chucks on metal and what not. Do this , if you open it up before removing anything , take a little telescopic magnet stick for like retrieving screws and bolts and poke it around gently inside and see what you come out with.
Ok, nothing yet. I'll update tomorow.
